Jackalope02 Posted January 27, 2004 Share Posted January 27, 2004 I am concerned about a '96 Outback that I recently purchased. It has the 2.5 with Automatic Trans. It runs at 3,000 RPM at 75mph. Is that normal? It seems a bit high, but this is my first Subaru. Any help would be greatly appreciated. Mike Link to comment Share on other sites More sharing options...
Commuter Posted January 27, 2004 Share Posted January 27, 2004 Right on the mark... I think I hover just under 3k, eg 2900 at that speed. 97 OB auto. The gearing is kept a bit short on these cars since they really are a bit underpowered if you ask me. The higher revs give one a bit better pick up, but they still rate near the bottom of the pack for acceleration in their class. Decent torque though from the H4. Commuter Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 27, 2004 Share Posted January 27, 2004 I think my '03 H6 is about the same. Link to comment Share on other sites More sharing options...
Jackalope02 Posted January 27, 2004 Author Share Posted January 27, 2004 Thanks! I was a bit worried that maybe the OD was gone. Mike Link to comment Share on other sites More sharing options...
wrxsubaru Posted January 27, 2004 Share Posted January 27, 2004 A Geo traker is at around 4500 RPMs at 75mph thats short gearing. Link to comment Share on other sites More sharing options...
nickb21 Posted January 27, 2004 Share Posted January 27, 2004 Think my 5spd OB pulls almost 3500 at 75mph, took a little getting used.. seems the rev's flatten out a bit too when you get up to 85 - 90. Link to comment Share on other sites More sharing options...
rcoaster Posted January 27, 2004 Share Posted January 27, 2004 You're right on the button. My 96 Outback revs at 3K while at 75 mph. Link to comment Share on other sites More sharing options...
mattocs Posted January 27, 2004 Share Posted January 27, 2004 My 1995 Legacy (5 sp.) does 3k RPM @ 70MPH Link to comment Share on other sites More sharing options...
frag Posted January 27, 2004 Share Posted January 27, 2004 Mattocs, same with my 96 2.2L But the engine does'nt sound busy at that rpm. Smooth... Link to comment Share on other sites More sharing options...
Commuter Posted January 28, 2004 Share Posted January 28, 2004 Originally posted by 1 Lucky Texan I think my '03 H6 is about the same. When I test drove an Outback VDC a couple years ago, I noticed that the revs were a bit lower. About 2500 rpm IIRC at 75 mph. My wife's 99 Honda Odyssey with 3.5L V6 turns over at 2000 rpm at 75 mph. Gets about the same gas milage too as my 97 OB Phase I 2.5L engine. Hmmm... Commuter Link to comment Share on other sites More sharing options...
Setright Posted January 30, 2004 Share Posted January 30, 2004 These engines all have a shorter stroke compared to their bore. That translates to crummy low rev torque, which is why they need to pull such "high" revs. It's also means that high revs are possible, like sticking with 1st 'til 6500rpm and staying in 2nd til 6000rpm. In the higher gears the torque drop off after 6000rpm becomes a problem and I usually shift around 5500rpm, which brings the revs back to the torque peak. Of course this is only when I am hurrying Link to comment Share on other sites More sharing options...
WagonsOnly Posted January 30, 2004 Share Posted January 30, 2004 Of course:D My '99 Forester (Phase II 2.5) is around 3200 @ 75. But it's a 5-speed. (For some reason the 5-speeds are geared shorter than the 4EATs.) My mom's '82 GLF turns 4000 at 70--but that's with a 3-speed auto slushbox. So by comparison Subaru is getting better. Link to comment Share on other sites More sharing options...
