Throttlebody Help
Hello to all
Have a 1988 DL wagon 5 speed. How do i troubleshoot the trottlebody.This car has sat 3-4 years.I have clean gas to throttlebody will start runs 5 seconds and dies. I can pour gas into the throttlebody and it will run for say 30 seconds they want $60 for the injecter and $85 for the pressure reg how can I tell what I need.I know nothing about these cars just helping out a neighbor lady that delt with guys that took her money and tore the car apart.I really like this little car. Thanks for your help...Bob
Did you check for codes?
http://www.ultimatesubaru.org/forum/showthread.php?t=49918
A faulty MAF might cause this. Unhook the intake boot and the MAF connector then have a freind crank the car while you look to see what the injector spray looks like. If you are trying to run the car with the boot off the TB and the MAF plugged in it will not work. I would think if the regulator was bad you would at least get it to start and run a little bit. If the IAC or CTS were bad you should be able to keep it running with the throttle.
Edited by ihscout54
