July 28, 200916 yr Anyone ever use this company? http://www.performancepeddler.com. Im was looking for a set of front KYB Shocks for my 01 OBW VDC. They seem to have the best prices at 84.47 each with free shipping and if you log in with the ebay code of "ebay4p" you get another 10 percent off of orders over $150. Im going to give them a try.....Brad
July 28, 200916 yr Regardless where you purchase, you have chosen well to buy KYB shocks/struts. They are my first choice. KYBs have always performed well for me, plus they are reasonably priced.
July 28, 200916 yr tKYB is the oem equipment manufacturer for Subaru. . unless you have spec B and then its bilstein. not sure on Sti. my experience with the Kyb though, is the silver paint is very thin, and cheap, and mine got rusty looking after a couple winter months. subaru must have a better grade of paint spec'd on the oem version, they are black and more durable paint. I would suggest to paint over the silver with spray paint before installing to make them stay looking new. Edited July 28, 200916 yr by bheinen74
July 29, 200916 yr Author tKYB is the oem equipment manufacturer for Subaru.. unless you have spec B and then its bilstein. not sure on Sti. my experience with the Kyb though, is the silver paint is very thin, and cheap, and mine got rusty looking after a couple winter months. subaru must have a better grade of paint spec'd on the oem version, they are black and more durable paint. I would suggest to paint over the silver with spray paint before installing to make them stay looking new. I would have loved to put Bilstein shocks on the VDC but they don't make them for the 01 Outbacks. They do make them for the Legacy but the price was astronomical for a pair, and I kinda doubt they would be the right fit for an OBW. Does any one know why H6 Outbacks and H4 Outbacks used the same shocks? I would think the H6 would be more weight on the front suspension requiring a beefier shock. Is the H6 and H4 engines about the same weight? Will take you advice and put another coat of paint on them, since i will be driving in winter allot with this car. I put a set of Kyb's on my 97 obw, haven't check to see how the paint was holding up on it.
July 29, 200916 yr Does any one know why H6 Outbacks and H4 Outbacks used the same shocks? I would think the H6 would be more weight on the front suspension requiring a beefier shock. Is the H6 and H4 engines about the same weight? For the most part all the shock does it keep the car from bouncing. The spring is what holds up the weight. But really 2 extra cylinders is maybe another 75 or 100 lbs at most. Placed in the right spot between the axles you wouldn't even notice that much weight difference.
