jayare12 Posted July 29, 2009 Share Posted July 29, 2009 well i just bought a 1978 with a six inch lift and the strut towers are giving me a camber issue\ / (dont know if thats positive or negative) but it feels like I cant control it above 50 mph. any suggestions or now where i can get some 6" strut tower adapters? Link to comment Share on other sites More sharing options...
michael appel Posted July 29, 2009 Share Posted July 29, 2009 what type of tire are you running? check the rest of the suspension to see how loose things are Link to comment Share on other sites More sharing options...
jayare12 Posted July 29, 2009 Author Share Posted July 29, 2009 just the stock 13s was thinking of trying to fit larger tires on it. also working on fixing front strut lifts i dont think he did the math for figuring what angle was needed i figure the mount is roughly 14 deg at top and rather than adjust and come straight down i think he just ran straight six inches out. Oh yeah mike you still know that guy how makes the lifts? Link to comment Share on other sites More sharing options...
jayare12 Posted July 30, 2009 Author Share Posted July 30, 2009 also can anyone link me a photo or drawing of some sturdy strut lifts, all i can find is 4 inch would like to see how others are done. i was thinking or useing two inch square tube with 14 degree cuts so strut mount is at right angle. would love to hear others desighn or suggestions. Link to comment Share on other sites More sharing options...
SoobieDoo Posted July 30, 2009 Share Posted July 30, 2009 Is it strictly a suspension lift? With that much lift, and no body blocks, I'm surprised it's even driveable! Link to comment Share on other sites More sharing options...
jayare12 Posted July 30, 2009 Author Share Posted July 30, 2009 No it has a six inch body lift but I'm not worried about those blocks they are pretty stout. I am just wanting to fix the front camber issue. Link to comment Share on other sites More sharing options...
carfreak85 Posted July 30, 2009 Share Posted July 30, 2009 I ran across a pretty gnarly lifted Gen 1 BRAT in the Lynnwood PAP years ago that apparently once belonged to a member of the Hatch Patrol. Don't know his name, but I grabbed a few of its parts, all of which have been lost. I think one of Zap's old Subaru Fun videos featured it once or twice, but I could be wrong. Maybe one of the vets could speak up on this? Not many people have lifted a Gen 1 BRAT or any Gen 1 for that matter and all are basically custom one-offs, not a production type kit. There are several fabricators who are members here who would probably be glad to help. Link to comment Share on other sites More sharing options...
michael appel Posted July 30, 2009 Share Posted July 30, 2009 A bigger wider tire will help with the camber also send me a pic on the way it looks it will have some off camber and it will be bad with 13s they are pizza cutters so the ride will be different because you are higher in the air with little tires so they tend to track a little differently send me a pic and I can help but far as I can tell you is with a 4 inch there is bad camber I took my car to the shop and they maxed out everything on the front to get the camber right but the only way you can get it to be even is by making the bottom arms longer Link to comment Share on other sites More sharing options...
jayare12 Posted August 5, 2009 Author Share Posted August 5, 2009 well i installed the pieces i built for the front strut mounts and it sucked the top of the tires in a inch, So i guess compensating for the angles and lift are important. gonna tighten everything up and test drive tonight after the comes home. also how do i post photos do i need a online pic account? Link to comment Share on other sites More sharing options...
Mugs Posted August 5, 2009 Share Posted August 5, 2009 I suggest getting a hold of "The Beast I Drive" he is the brat king and master lift maker. They are military tank quality and have all the correct camber angles. But keep in mind you will have some camber with a lift that big, it is just a fact of life. Either deal with or go back to mamby pamby stock. Link to comment Share on other sites More sharing options...
jayare12 Posted August 10, 2009 Author Share Posted August 10, 2009 Well The problem is solved, so for anyone who searches this thread for answers my problems were that the guy who built the lift before i bought it did not compensate for strut mount angles, so the front strut was bound up. Also he clocked the rear torsion bars so the rear was about 3" higher than the front end, which in turn messed up the caster on the front end. After everything was done went for a test drive and got it to 70mph(downhill) not A wobble also the alignment must be good cuz it goes straight even with no hands on the wheel. I'm thrilled to have it on the road and running again. Link to comment Share on other sites More sharing options...
danrenfroe2016 Posted August 12, 2009 Share Posted August 12, 2009 (edited) jayare12 said: Well The problem is solved, so for anyone who searches this thread for answers my problems were that the guy who built the lift before i bought it did not compensate for strut mount angles, so the front strut was bound up. Also he clocked the rear torsion bars so the rear was about 3" higher than the front end, which in turn messed up the caster on the front end. After everything was done went for a test drive and got it to 70mph(downhill) not A wobble also the alignment must be good cuz it goes straight even with no hands on the wheel. I'm thrilled to have it on the road and running again. Very good Information, I am in the process of lifting the Front of my 80 Brat... do you have any pictures? I have not even though about the rear yet...:-\ I am only going 2 Inches or 2.5 Inches for the front square Tube Method... Also how was the rear done? Please provide Pictures. as I only want to raise the rear about 1" or so... Thanks. -Daniel Edited August 12, 2009 by danrenfroe2016 Clarification Link to comment Share on other sites More sharing options...
jayare12 Posted August 12, 2009 Author Share Posted August 12, 2009 http://s796.photobucket.com/albums/yy242/jayare12/ here is some photos Link to comment Share on other sites More sharing options...
danrenfroe2016 Posted August 12, 2009 Share Posted August 12, 2009 Thanks for the pics... That is quite a lift! I just want to go up a little in the front to match the unloaded rear and Also fix a bent front strut. It looks like I will probably leave the rear where its at as it is a lot of work... -Daniel Link to comment Share on other sites More sharing options...
