tforce Posted August 1, 2009 Share Posted August 1, 2009 Anyone found seats that will bolt right in to an ea81? I've heard that maybe XT6 seats. If I have to make rail adapters that's ok.....what seats will fit ok as far as total height? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 1, 2009 Share Posted August 1, 2009 Just about anything will fit with modification. I generally use EA82 or Legacy seats when I convert. Nothing out there is a straight bolt-in. If you are looking for more height (lower seat), the best I've found is from an 80's Isuzu Impulse. 3 of the 4 holes for the EA81 rails line up on them. That's about as close to bolt-in as you are going to get. EA82 seats are easy to adapt - you make 4 tabs to weld to the seat frame to offset the rails inward by 1.5" IIRC. I just wrap the seat in wet rags and weld the tabs on - bolt on the rails and bolt them into the car. Takes about an hour. GD Link to comment Share on other sites More sharing options...
