loyale gas milage issues
my 1990 loyale spfi 5 speed single range 4x4 is getting 14 miles per gallon. which sucks.
My carbed wheeler wagon with a craptachi and 28's is getting 26 mpg, so i know the loyale should be getting better milage
Does anyone know what is making the loyale have crappy gas milage? What should i do to fix it?
Thanks!
John
Edited by Markus56
Okay... What have you checked so far? I'm not really up on the EA-82s, but here's what I'd go through on pretty much any car; modify recommendations as necessary to suit your situation:
- Is the math on the fuel economy correct? (I've got this one wrong before)
- Is the fuel you've got OK? (drain / run out tank, fill up at a different station)
- Spark plugs (cracked, worn out, what sort of colouration?)
- Plug wires (are they oil-soaked, cracked, and / or showing arcing?)
- Distributor cap (check for cracks and broken / worn contacts)
- Rotor arm (check tip and centre for wear)
- Ignition coil (if you shake it, can you hear the oil sloshing around inside? If not, time for a new one)
- Fuel filters (clogged / cracked?)
- Fuel lines (cracked?)
- Vacuum leaks (got any?)
- Timing (no misses or flat spots, distributor / shaft bushings OK?)
- Carb / FI (is it running rich or leaking; injector(s) & sensors OK?)
That's more or less the order I'd check it out in. Need some more info before we can really give you an idea, though.
Edited by casm
yeah, i should probably do that. i was hoping i wouldn't have to spend money :rolleyes:
but i guess it will save me money in the long run :-p
Nah, just check the basics yourself first. A lot of this doesn't require specialised knowledge, just the ability to pull spark plugs, unbolt a coil, etc. If you can get us whatever you can, it helps to track stuff down - which in turn can end up saving you money even if you decide to have someone else do the work.
I meant spending money on parts. but when your car has 260 thousand miles on it, you should probably replace the old stuff on it :lol:
Oh, yeah, that's worth opening up the wallet for :D Good luck!
