Low Oil Pressure EA82
Yesterday I pulled the trigger on my latest 4x4 project. It's an '89 GL with a carb & dual range 5 spd. I've only owned it for a day and already love it. More explanation on that to come...
As I was driving it home I noticed that after it warmed up, the oil pressure gauge was reading a lower than normal pressure.
At idle it sits at maybe 10 psi and at 4000 rpm it slowly moves up to just under 45 psi. The engine doesn't burn any oil and there are no ticky valves.
Any thoughts?
I'm thinking any of these things:
-sending unit
-pump
-crankshaft bearings?
Thanks in advance. This forum is invaluable.
Thanks. I wasn't really worried about running it at those pressures, but this is my first EA82 and I'm not really sure what to expect as far as the idiosyncrasies. What is "normal" oil pressure on this engine?
OK, I should say thanks to the other oil pressure threads. After reading the related threads I think I'll get one of those little after market gauge clusters and throw it in with a new sender. That sounds a little bit more reliable than the stock gauge. Maybe I'll get one with temp, too.
