hoverman37 Posted August 7, 2009 Share Posted August 7, 2009 Hello, I bought a EA82T for a Hovercraft and the Turbo unit is in the way of my Propeller mounts, Can I remove the Turbo and still use the Motor? Thank you for the help, I am struggling trying to find info, Scott Link to comment Share on other sites More sharing options...
Turbone Posted August 7, 2009 Share Posted August 7, 2009 Yes it will, but the compression ratio for those engines are only 7.7:1 Not to mention you will need the ECU and knock sensor. Link to comment Share on other sites More sharing options...
Numbchux Posted August 7, 2009 Share Posted August 7, 2009 yea, it'll run. but it won't have any power (N/A compression EA82s only have like 90. a turbo compression one without the turbo.....yea). you can relocate it. wouldn't be too difficult to fabricate some exhaust tubing and oil/coolant lines to put it wherever you need it. Link to comment Share on other sites More sharing options...
john in KY Posted August 8, 2009 Share Posted August 8, 2009 How difficult would it be to "flop" the exhaust manifold? Turbo then would be positioned in the area where the alternator is now. Link to comment Share on other sites More sharing options...
Niku-Sama Posted August 8, 2009 Share Posted August 8, 2009 in order to "flop" it yous be making a new one. which isnt a bad idea but sounds like alotta work Link to comment Share on other sites More sharing options...
Numbchux Posted August 8, 2009 Share Posted August 8, 2009 john in KY said: How difficult would it be to "flop" the exhaust manifold? Turbo then would be positioned in the area where the alternator is now. you'd have to cut and re-weld the flanges, as they'd be 90 degrees off...and I don't think the crossover would clear the oil pan. would be easier to weld up a new system, you could probably re-use the stock header, and just make a new up-pipe that relocates the turbo. Link to comment Share on other sites More sharing options...
hoverman37 Posted August 8, 2009 Author Share Posted August 8, 2009 Thank you all for the advice, Sounds like i rushed into buying the wrong engine. I am going to mount the Turbo back on and then start over on my engine mounts and pullys and try to get this running. This is a great message board. Thanks, I am sure I will have more questions. Scott Link to comment Share on other sites More sharing options...
Gloyale Posted August 8, 2009 Share Posted August 8, 2009 if you are willing to pul the heads, remove and swap the pistons out to some N/A pistons you'll have a pretty good motor. Link to comment Share on other sites More sharing options...
hoverman37 Posted August 8, 2009 Author Share Posted August 8, 2009 Being the compression difference, what kind of HP would it still produce without the turbo? I only need about 70HP. Tks Scott Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 8, 2009 Share Posted August 8, 2009 hoverman37 said: Being the compression difference, what kind of HP would it still produce without the turbo? I only need about 70HP. Tks Scott I don't think you would hit 70 without the turbo. The non-turbo engines were 84 HP with 9.0:1 compression. I wouldn't be surprised if it were around 60 to 70 without the turbo. It would be a gamble I wouldn't want to take - especially with a used engine. What you need is an EA81 - 73 HP, no timing belts, lighter and smaller. GD Link to comment Share on other sites More sharing options...
P K Posted August 8, 2009 Share Posted August 8, 2009 I drove a 1986 sedan where the guy installed a JDM turbo shortblock (low compression) to replace his NA motor, using all his NA manifolds, etc. It was unacceptable. Hills were scary slow. Think 1980s diesel rabbit but without the torque . Link to comment Share on other sites More sharing options...
someguy Posted August 9, 2009 Share Posted August 9, 2009 GeneralDisorder said: What you need is an EA81 - 73 HP, no timing belts, lighter and smaller. GD +1 the EA81 is the subaru engine of choice for light aircraft/hovercraft projects. Link to comment Share on other sites More sharing options...
Ginger48 Posted August 16, 2009 Share Posted August 16, 2009 someguy said: +1 the EA81 is the subaru engine of choice for light aircraft/hovercraft projects. 9 years ago a friend of mine took me for a ride in his Subaru powered gyrocopter. It was powered by an EJ engine with a distributor and holly carburetor. The pilot and craft are now somewhere on the bottom of Lake Michigan. Subaru's are safer on the ground. Link to comment Share on other sites More sharing options...
Txakura Posted August 17, 2009 Share Posted August 17, 2009 this is kind of moot, the poster posted that long enough to hear yes, 'but not very well', offered the engine to anyone that wanted it, gave it to some one off line then disappeared dead thread Link to comment Share on other sites More sharing options...
