92 loyale no start
My car was showing some hesistance in the past week. Now it will turn over and I have spark to all cylinders. Fuel pump pressure is 24psi with clean filters,but it won"t start. I have very little hair ,but I'm ready to tear it out. Can anyone suggest what to check next? Regards
I guess I'd check for compression in all cylinders. Ideally,you would have
150 lbs/psi or so,in each hole. If you have good compression,then I'd be looking at a possible plugged exhaust. Like maybe the cat is plugged.
Edited by markjw
