EA82 woes
1987 gl hatch. so heres the problem. my timing belt snapped, got it replaced, then all hell broke loose. now i have a slight knock on the passenger side of the engine. is there a simpler way to fix other then a rebuild, or would it be easier to swap the engine for an ejxx?:-\
He has an '87 three door coupe if it's got the EA82.
This "knock" - what does it sound like? Could it be a lifter tick? Could the belt be off a tooth?
Just having a belt snap will not damage an EA82. This knock is either unrelated, pre-existing, or due to incorrect assembly/adjustment.
