Lift kit for 92' Loyale
Ubersuber420
With a 3" you should be able to run 27-28" with no problems, you may still need to trim the front fenders due to turning clearances.. Now keep in mind with any Lift higher then 2" the steering shaft that go's to the steering box will need to be longer, since the 3" and up will require using Crossmember blocks, droping the engine 2" or so inches to keep the stress on the axles closer to stock.
Anyhoo, I run SJRs 2" lift with 26" tires (Works great) anything over 28" on the auto trans and it'll start lagging.
Best'O luck
-Tom
Edited by TheLoyale
Hey, I was wondering where i could get a 3'' lift for my loyale. I live in island county in WA, and was hoping for something local. Also, what size of tires could a lift like this clear? Thanks in advance.
I have a '92 Loyale with a lift and it is a ton of fun! I would go with a SJR kit that's posted above. Have Fun!
  • 2 weeks later...
