gcleeton Posted August 15, 2009 Share Posted August 15, 2009 Code says 'Throttle sensor' on 97 Outback Sport Impreza. Please what effects might be observed? Link to comment Share on other sites More sharing options...
EVOthis Posted August 15, 2009 Share Posted August 15, 2009 stalling..What code was it exactly? P???? Link to comment Share on other sites More sharing options...
OB99W Posted August 16, 2009 Share Posted August 16, 2009 (edited) Code says 'Throttle sensor' on 97 Outback Sport Impreza. There are several codes related to the throttle position sensor. What's the specific code (not the code definition)? Please what effects might be observed? In addition to stalling as already mentioned, the idle quality and engine performance in general can be compromised. Also, automatic trans operation can be affected by incorrect TPS data. EDIT: By the way, the problems might be intermittent. Edited August 16, 2009 by OB99W Link to comment Share on other sites More sharing options...
davebugs Posted August 16, 2009 Share Posted August 16, 2009 There was a rash of these last year suddenly. I sold 3 in a few weeks and that's all that I sold last year. Do some additional research. I'd consider swapping the whole throttle body rather than trying to set that sensor. I'm a little electrically challanged though. So resetting it looks lika e huge pain to me. The screws that hold in that sensor I use an impact on - they are easy to screw up the heads on. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 17, 2009 Share Posted August 17, 2009 In my experience most TPS codes are because of a dead spot in the sensor. This can cause the engine to surge or not respond at all. Its not hard to replace it, but you should post the actual code here for some further information before you go buying one. Link to comment Share on other sites More sharing options...
Subcrates Posted March 25, 2016 Share Posted March 25, 2016 My 2004 6h outback displayed code P0122. Is it possible to find Haynes or any repair manual. Apparently the Haynes manual does not include info on the 6 cyl.! Link to comment Share on other sites More sharing options...
