one eye Posted August 17, 2009 Share Posted August 17, 2009 (edited) T-Roy made his way up to my place this weekend and we made his car a little taller....................... Before.................................................... Now The front is up.................................... This is just a 2" lift like all the others....................:grin::banana: Jeff Edited August 17, 2009 by one eye Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 17, 2009 Share Posted August 17, 2009 Jeff, if I may make a suggestion, I noticed on those straps you use in the rear you have no bracing to keep them from bending in a hard drop, maybe weld a small plate brace in on the inside edge of the straps for the added strength, and maybe a brace between them to keep them from swinging front or rearward.... Of course this is just my thoughts, I build all my stuff way overkill Looks good though -Bill Link to comment Share on other sites More sharing options...
SoobieDoo Posted August 17, 2009 Share Posted August 17, 2009 T-ROY!!! Looks like you're a lil better off for evans now. If you ever make it back up this way, you've just gotta try the "faceplant hole" again...prob make it fine now! Link to comment Share on other sites More sharing options...
one eye Posted August 17, 2009 Author Share Posted August 17, 2009 T-roy has made it back to my place as he has blown his motor.............. he is getting bolts right now at the local Lowes....... but we have another motor here at least, it has been a long assed day so far.............:-\ Jeff Link to comment Share on other sites More sharing options...
one eye Posted August 17, 2009 Author Share Posted August 17, 2009 Jeff, if I may make a suggestion, I noticed on those straps you use in the rear you have no bracing to keep them from bending in a hard drop, maybe weld a small plate brace in on the inside edge of the straps for the added strength, and maybe a brace between them to keep them from swinging front or rearward.... Of course this is just my thoughts, I build all my stuff way overkill Looks good though -Bill Bill it would be a good Idea but there has been no problems so far, none of them have spun off to the side............ one guy has been able to blow the strut off the bottom side and all the blocks stayed in there place....... Jeff Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 17, 2009 Share Posted August 17, 2009 Bill it would be a good Idea but there has been no problems so far, none of them have spun off to the side............ one guy has been able to blow the strut off the bottom side and all the blocks stayed in there place....... Jeff Hey if it works, let it be Like I said, Im overkill -Bill Link to comment Share on other sites More sharing options...
STI_Wolf Posted August 17, 2009 Share Posted August 17, 2009 too bad I broke down right after i got the lift..:-\ I guess I'll have to test it tomorow evening. Link to comment Share on other sites More sharing options...
superu Posted August 17, 2009 Share Posted August 17, 2009 Holy cow!! Man those lil block lifts are the way to go huh?!! Anybody have input yet if that would go in new gen subies? I've interested in an inch of lift (via blocks) in my 95 OB-strutted legacy. Thanks and looks good, and SO simple.. Link to comment Share on other sites More sharing options...
Mechanical_misfit Posted August 19, 2009 Share Posted August 19, 2009 I'm also wondering if this would work on a new soob GLs are extinct in this part of the country (MI) I have the only GL 3 door I've ever seen in person, wich has this lift, but is getting rusty. I just picked up a 98 Outback sport, and did the Legacy OB lift, But would do more if anyone knows about wear and tear. Link to comment Share on other sites More sharing options...
TheLoyale Posted August 19, 2009 Share Posted August 19, 2009 Thats only 2"!!?? Looks higher then mine, is he running 15s? Might be why.. Anyhoo, Jeff looks awesome. I take it Troy is happy now? :-p Too bad you guys gotta swap engines right before EC But hows it coming along? -Tom Link to comment Share on other sites More sharing options...
The Scooby Posted August 19, 2009 Share Posted August 19, 2009 i think its looks so much taller is because the tire size as well as the fact that the fender wells are choped out a bunch. Link to comment Share on other sites More sharing options...
one eye Posted August 19, 2009 Author Share Posted August 19, 2009 Anyhoo, Jeff looks awesome. I take it Troy is happy now? :-p Too bad you guys gotta swap engines right before EC But hows it coming along? -Tom We got the motor in and everything swaped out over the next day, It was quite a bit of work but Rick and I got it done................ Jeff Link to comment Share on other sites More sharing options...
TheLoyale Posted August 19, 2009 Share Posted August 19, 2009 Yea thats probably why it looks taller, Jeff, whoot! Its good when you have another person to help out! btw, We need a far veiw shot by another vehicle to see the extra 2":headbang: -Tom Link to comment Share on other sites More sharing options...
kanurys Posted September 2, 2009 Share Posted September 2, 2009 Nice job. And looks like a clean job on those drilled out rims. Link to comment Share on other sites More sharing options...
Zefy Posted September 27, 2009 Share Posted September 27, 2009 what size tires are those? looks sweet! i'm gunning for the same setup. Link to comment Share on other sites More sharing options...
one eye Posted September 27, 2009 Author Share Posted September 27, 2009 30's!!!! Jeff Link to comment Share on other sites More sharing options...
Gloyale Posted September 27, 2009 Share Posted September 27, 2009 Holy cow!! Man those lil block lifts are the way to go huh?!! Anybody have input yet if that would go in new gen subies? I've interested in an inch of lift (via blocks) in my 95 OB-strutted legacy. Thanks and looks good, and SO simple.. With outback struts on a Legacy, you have already pushed the springs up. If you put a block onto of that, you're axles will be at too extreme of an angle. Link to comment Share on other sites More sharing options...
michael appel Posted September 27, 2009 Share Posted September 27, 2009 I'm also wondering if this would work on a new soob GLs are extinct in this part of the country (MI) I have the only GL 3 door I've ever seen in person, wich has this lift, but is getting rusty. I just picked up a 98 Outback sport, and did the Legacy OB lift, But would do more if anyone knows about wear and tear. Go to bangor my mom now has the only 6 inch lifted 1986 wagon with no rust in michigan she is the post office worker in bangor and people are like what the f/// is that thing Link to comment Share on other sites More sharing options...
superu Posted September 28, 2009 Share Posted September 28, 2009 With outback struts on a Legacy, you have already pushed the springs up. If you put a block onto of that, you're axles will be at too extreme of an angle. But by putting blocks on, doesn't that just push the body up off the suspension, like body lift vs. a suspension lift of the 'ol 4x4s? Ooh, wait its a unibody, so pushing the body up pushes engine/tranny up too, huh? Hmmmm, I see. Well i did just recently get the engine x-member blocks from a forester and the rear sway arms and brackets from an outback to fit into my lego.. So that'll push the engine down close to an inch and lesses the axle angles up front, then the rear swing arm bracket also pushes things down the same distance so that should help angles too, right? I'm thinking scorpion springs and considering scorpion raised spings vs. a 1" block kit (like from jackson rally, but this looks simpler and cheaper)... :-\ BTW, Nice work on these little lift block sets ya'll!!! Link to comment Share on other sites More sharing options...
Turbone Posted September 28, 2009 Share Posted September 28, 2009 30's!!!! Jeff Not 44"s? Link to comment Share on other sites More sharing options...
3eyedwagon Posted September 28, 2009 Share Posted September 28, 2009 ^ 37s :-p Link to comment Share on other sites More sharing options...
one eye Posted September 29, 2009 Author Share Posted September 29, 2009 Not 44"s? That's what I ment 44's.............. 44 Jeff Link to comment Share on other sites More sharing options...
SOUTHPARK SLIM Posted November 13, 2009 Share Posted November 13, 2009 love it ,any picts of the steering linkage u joint? Link to comment Share on other sites More sharing options...
one eye Posted November 14, 2009 Author Share Posted November 14, 2009 love it ,any picts of the steering linkage u joint? It's stock, this is all in the struts, none of the crossmembers are dropped Jeff Link to comment Share on other sites More sharing options...
