Cyfun Posted July 29, 2012 Share Posted July 29, 2012 Ah okay, that makes sense. Where did you put your MAF, though? It looks like the airbox is right up against the throttle. Link to comment Share on other sites More sharing options...
Gloyale Posted July 29, 2012 Share Posted July 29, 2012 Cyfun said: Ah okay, that makes sense. Where did you put your MAF, though? It looks like the airbox is right up against the throttle. looks like a MAP based, phase II engine. Link to comment Share on other sites More sharing options...
Tosh Posted July 30, 2012 Share Posted July 30, 2012 Gloyale said: looks like a MAP based, phase II engine. That is correct. 2001 EJ22 from an outback sport, No maf. Link to comment Share on other sites More sharing options...
subaruman5 Posted December 5, 2012 Share Posted December 5, 2012 (edited) Thanks for all the suggestions in this thread. I went with the: K&N Apollo Cold Air Intake Systems Universal & Stone For 96-03 Toyota 90 series Landcruiser Prado Snorkel Air Intake Snorkeling Most challenging part was getting everything to fit and find the proper adapters, but I found some at the local hardware store and in my tool box. Also had to reroute one of the hoses from the idle control valve and had to relocate one of the plastic fittings on the intake piping. They say that the intake head is designed to be in forward position with escape channels that the ram air forces the dissipated water particles to drain from, but I don't trust it and drive with it faced aft just in case. Other wise, I have not integrated a drain hole yet. As long as I periodically clean the air filter it should be fine. Anyways enjoy the pictures! Bryan Edited December 5, 2012 by subaruman5 Link to comment Share on other sites More sharing options...
Cyfun Posted December 6, 2012 Share Posted December 6, 2012 Kitty! Looks great! Very clean. My only concern with such a setup is that it could be easy to damage if it's sticking out the side like that. I like your waterproof ammo box in the spare tire location, been considering doing that to store my stereo amp. What do you have hiding in there? Link to comment Share on other sites More sharing options...
subaruman5 Posted December 6, 2012 Share Posted December 6, 2012 Thanks! Basically everything from under the passenger dash including ecu and relays were relocated to the ammo box in the engine bay. No need having to work under dashboard anymore:) Link to comment Share on other sites More sharing options...
Cyfun Posted December 6, 2012 Share Posted December 6, 2012 Great idea! Would make doing the EJ swap a lot easier if you didn't have to reroute everything to the interior. How'd you make it so the wires can get in but it's still water tight? Link to comment Share on other sites More sharing options...
superu Posted December 8, 2012 Share Posted December 8, 2012 congrats on picking up this hatch!! It's a sweet rig! subaruman5 said: Thanks for all the suggestions in this thread. I went with the: K&N Apollo Cold Air Intake Systems Universal & Stone For 96-03 Toyota 90 series Landcruiser Prado Snorkel Air Intake Snorkeling Most challenging part was getting everything to fit and find the proper adapters, but I found some at the local hardware store and in my tool box. Also had to reroute one of the hoses from the idle control valve and had to relocate one of the plastic fittings on the intake piping. They say that the intake head is designed to be in forward position with escape channels that the ram air forces the dissipated water particles to drain from, but I don't trust it and drive with it faced aft just in case. Other wise, I have not integrated a drain hole yet. As long as I periodically clean the air filter it should be fine. Anyways enjoy the pictures! Bryan Link to comment Share on other sites More sharing options...
subaruman5 Posted December 9, 2012 Share Posted December 9, 2012 Cyfun said: Great idea! Would make doing the EJ swap a lot easier if you didn't have to reroute everything to the interior. How'd you make it so the wires can get in but it's still water tight? It simply isn't water tight, but silicone and rubber grommets is best I could come up with including hole for wiring going to the ammo box. It is what it is:) Link to comment Share on other sites More sharing options...
Cyfun Posted December 9, 2012 Share Posted December 9, 2012 I was gonna run mine through the firewall and possibly weld or glue it up, that way it's sealed off from the engine bay and gets air and wiring from under the dash, should be fairly water tight from the inside. Since I was gonna have an amp in there, was prolly gonna need a small 12v computer fan to cool it. Link to comment Share on other sites More sharing options...
Uberoo Posted December 9, 2012 Share Posted December 9, 2012 cyfun how are you sealing your intake where the silicone coupler slips INTO the PVC? On my own snorkel setup joints like that are a constant source of leaks.I redesigned the snorkel to remove some of those but still some remain... Link to comment Share on other sites More sharing options...
Cyfun Posted December 9, 2012 Share Posted December 9, 2012 Uberoo said: cyfun how are you sealing your intake where the silicone coupler slips INTO the PVC? On my own snorkel setup joints like that are a constant source of leaks.I redesigned the snorkel to remove some of those but still some remain... Sadly, I haven't gotten to the point of attaching snorkel piping yet, my Sooby is still up on blocks in the driveway, waiting for me to finish lifting it a few more inches. But the plan is probably to use some good epoxies and not silicone. I have, however, relocated the EJ22 airbox up to where the spare tire mount is, so it's nice and high and far back. Link to comment Share on other sites More sharing options...
Uberoo Posted December 10, 2012 Share Posted December 10, 2012 I have hydrolocked 3 engines that had the airbox up where the spare tire sits. My airbox is up at the top of the car but it still isnt 100% leakproof. The space where the spare tire used to sit is now filled with an ammo box holding my ECU and relays and stuff.I used cut vacuum lines to line the edges of the holes for the wires than I filled them in with expanding foam and so far it seems to be working. Link to comment Share on other sites More sharing options...
