SUBIgoNEwer Posted August 17, 2009 Share Posted August 17, 2009 Are cvaxles supposed to move in and out from the tranny? My first suby. any help on that would be appreciated... Link to comment Share on other sites More sharing options...
idosubaru Posted August 17, 2009 Share Posted August 17, 2009 They have *some* play to them by design. The better questions are: What problem are you trying to track down. Obviously you just didn't to go playing with a CV axle one day. And then what vehicle and details of it? Link to comment Share on other sites More sharing options...
SUBIgoNEwer Posted August 17, 2009 Author Share Posted August 17, 2009 I have 91' loyale EA82. I just decided to wiggle each side with my hand and they were both equally loose. I never felt any reason to other than to check things out for myself as the previous owner says he did all the work/replacement himself, noting new cvaxles. Link to comment Share on other sites More sharing options...
Durania Posted August 17, 2009 Share Posted August 17, 2009 It does sound normal to me. I suggest making sure you have roll pins on the tranny side and that your axle nuts are tight on the wheel side. Link to comment Share on other sites More sharing options...
gwilson87 Posted August 18, 2009 Share Posted August 18, 2009 It does sound normal to me. I suggest making sure you have roll pins on the tranny side and that your axle nuts are tight on the wheel side. The shaft having a slight in and out play is normal but if the cups can slide away from the trans that on the other hand isn't. I concur with the check the roll pins, they can be little buggers to get in sometimes. Link to comment Share on other sites More sharing options...
