Help Identify Vacuum Hose EJ22 into 98 OBW Swap
Ok I have looked for hours and can't seem to find where this vacuum hose is supposed to go (red arrow):
It is the lower hose coming out of a rust colored connector under the passenger side of the intake manifold. There is a very long hose attached to the connector and I can't find where it goes. Any ideas?
Not ringing any bells for me. Perhaps someone else knows.
A pic of the back side of the intake (lower left in the existing pic - behind intake for cyl#3) would show whether there is a T in the line back there and other lines.
Do all lines appear accounted for? Sometimes I end up with a plug in the top hole (of the 2 holes) in the intake above cylinder #3, sometimes I don't. I just work through each one.
I'm shutting down for the night. Hopefully someone can recognize this and assist you.
I believe that you may be correct.
Thus my request for a photo of that area behind the intake for cyl#3.
I guessing either he's missing the T or the plug is in the manifold (where the 2 holes are close together above cyl#3) and he needs to remove the plug and put in a nipple.
