Zefy Posted August 22, 2009 Share Posted August 22, 2009 yup...some of you might remember me hinting at this over the last 3 years. well here it is. so it's all in. needs more bracing for me to be happy but my method seems to work. will update more as it gets done. i hope it works... Quote Link to comment Share on other sites More sharing options...
Pooparu Posted August 22, 2009 Share Posted August 22, 2009 Nice work. Love the rear coilovers. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted August 22, 2009 Share Posted August 22, 2009 I wouldn't recognize gen 1 rear suspension if I tripped over it.....is that stock gen 1 lateral links and such? or is that a whole EJ crossmember? either way.....hot! Quote Link to comment Share on other sites More sharing options...
Zefy Posted August 22, 2009 Author Share Posted August 22, 2009 the stock stuff is a torsion bar setup similar to the ea81 except it is in two pieces. here is one side after i took it out. this one has disc brakes from an RX on it. The diff mounts to a mustache bar just like the ea81's and the gas tank is above it. now you know what you are tripping over. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted August 23, 2009 Share Posted August 23, 2009 hehe, thanks so that is a whole EJ rear suspension setup in there, huh. F#$%in awesome!!!! Quote Link to comment Share on other sites More sharing options...
monstaru Posted September 2, 2009 Share Posted September 2, 2009 ************in sick..............nice job.cheers, brian Quote Link to comment Share on other sites More sharing options...
Psyko Posted September 2, 2009 Share Posted September 2, 2009 so that is a whole EJ rear suspension setup in there, huh. F#$%in awesome!!!! No kidding. I've been waiting for somebody to do this. Quote Link to comment Share on other sites More sharing options...
Jibs Posted September 2, 2009 Share Posted September 2, 2009 I thought the rear was the easy part. What are you doing about the front? Quote Link to comment Share on other sites More sharing options...
Zefy Posted September 2, 2009 Author Share Posted September 2, 2009 I thought the rear was the easy part. What are you doing about the front? front is easier. sort of... front is expencive... you need a different set of control arms. i got ones from crossbread performance in AUS. They let an ej knuckle/balljoint fit in an old gen control arm. beyond that, you need to either redrill/reinforce the strut tops or make a custom tophat for an ej style strut. i opted for a mishmash of both. Also a standard impreza spring doesn't fit into the tower. So you have to get a coilover style springpack. I am running rally spec hotbits coilovers. next thing you gotta sort out is the tie rod ends. OEM brat tie rods (inners and outers) fit into an impreza knuckle but the toe is all wrong. The tires are driving into each other. So you can swap in EJ outer tie rods. yup, they fit just fine. BUT! now you're to wide... So my solution is to run a modified set of ej outer tie rods (shortened and sleaved) but it is still not enough. So i'm going to shorten a bit of the brat inner rods. The axles are custom xt6 axles. I'm running an RX turbo transmission so i have 25 spline shafts. The shafts were shortened by rguyver. They have the correct inners and correct outers for an ej knuckle (in my case, 2.5rs) and they are the correct length to match the control arms. i'll post pics later. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted September 3, 2009 Share Posted September 3, 2009 you can't loosen the rod ends enough to get the EA81 ones to work? that's what I'm running on my loyale, works great. IIRC XT6 ones are somewhere between the EA81 and EJ rod ends in length, and use the larger taper stud. Quote Link to comment Share on other sites More sharing options...
Zefy Posted September 3, 2009 Author Share Posted September 3, 2009 Your loyal is substantially wider than the brat so I doubt that the same stuff would work. I also don't want to max out the tie rod as it is weaker. With that in mind, I'm sure there is some odd ball combo of inners and outers to give me my desired result however it is physically cheaper and easier to just cut stuff up. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted September 3, 2009 Share Posted September 3, 2009 Your loyal is substantially wider than the brat so I doubt that the same stuff would work. that's what I mean. if the EA81 stuff works in my loyale......I bet it would work better in a gen 1 either way, you wouldn't be the first to cut some length out of an EJ rod end. WJM cut an inch or so out of his when he did the 5-lug on his RX. Quote Link to comment Share on other sites More sharing options...
shuff Posted September 3, 2009 Share Posted September 3, 2009 so your brat, has the whole rear under side of a liberty (ej). nothing cut/re-joined? how is it bolted to the body (maybe some pic's)? sorry for the questions i just cant wrap my head around it... could this (with other slight mods) be adapted to work on L's? Quote Link to comment Share on other sites More sharing options...
