The Dude Abides Posted August 23, 2009 Share Posted August 23, 2009 I got new GL door panels for my car. Well the panels fit but the little trim piece that goes where the handle and lock are doesnt fit. Does anyone know if these are different then the DLs Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted August 23, 2009 Share Posted August 23, 2009 EA 81 or 2?.. The 81s should be the same unless it has power windows. I really dont know for 82s. Quote Link to comment Share on other sites More sharing options...
Txakura Posted August 23, 2009 Share Posted August 23, 2009 they should be the same, ea82... got a pic of 'doesn't fit'? run them down the door handle with the lock in the open position till it stops, then close the lock and slide the cup in place while it's closing - hard to slide them underneath Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted August 23, 2009 Author Share Posted August 23, 2009 Its for the EA82 I know how they fit but they dont sink in very far. The clip into place but they dont go in very far. I cant unlock and lock the door because it sits in further then the trip piece. Quote Link to comment Share on other sites More sharing options...
Txakura Posted August 23, 2009 Share Posted August 23, 2009 (edited) brb, I'll go pull one of mine and make some crappy cell pics to show the install... it just has a little trick to pop them in, think you're okay, just getting caught under the lock lever... sit tight **** ok, every once in a while my phone software decides to not communicate with the phone - this is one of those times it has to seat on the handle pin before it seats on the front edge slide it around the handle down to the closed (locked) lock lever, push gently in with your thumb to get the cup under the lock lever, open the door handle and get the two split clasps on the trim cup to seat on the door handle pin, top and bottom, push on the forward edge of the cup and it should snap in place up front mine have made the trip too many times, I have added some short screws to hold it from popping loose up front I'll post some pics when my effing software can connect to the phone Edited August 23, 2009 by Txakura phone Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted August 23, 2009 Author Share Posted August 23, 2009 I also wonder if the front and back door ones are diffrent. Maybe i have them backwards. The problem im also seeing is the pad is much thicker then my DL door pad used to be. Quote Link to comment Share on other sites More sharing options...
Txakura Posted August 23, 2009 Share Posted August 23, 2009 I also wonder if the front and back door ones are diffrent. Maybe i have them backwards. The problem im also seeing is the pad is much thicker then my DL door pad used to be. pad? hmm, pretty sure the front and rear are the same, cheaper to make 1 part than 2 do you mean that when everything is seated in place it sits up too high all the way around? I had thought you were not getting the clasps to slip over the door handle pin and it was holding it too high above the door panel maybe you better get a pic or two Quote Link to comment Share on other sites More sharing options...
Txakura Posted August 23, 2009 Share Posted August 23, 2009 does it look like this? Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted August 23, 2009 Author Share Posted August 23, 2009 When i get a second ill take a picture. Its almost like the pad is to thick and the trim piece doesnt sit far back enough into the doorpanel. Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted August 28, 2009 Author Share Posted August 28, 2009 Problem solved. I didnt have a couple tabs pushed in on the new door panels. Fits perfectly flush now. Now if only someone has a good set of 4 door trim pieces then i would be happy. Quote Link to comment Share on other sites More sharing options...
