Interchangability of legacy Front Springs
i have a '96 legacy awd wagon, brighton edition with a 2.2 and automatic. the roads in my city are awful and while replacing a ball joint, tie rod end and wheel bearing on the left side, i remove a broken part of the coil spring. i also noticed that both ends of the removed part were jagged, so it's been broken before.
the wrecking yards want to sell a complete strut to me and there don't seem to be any available aftermarket. the dealer is not an option as dealer parts here in Canada are a lot more than in the U.S.
there is one wrecker here that i might be able to talk into selling just the spring to me. unfortunately, the subaru he has is a '91 legacy sedan.
does anyone know if this will fit? i don't want to put a lot of money into this car as i want to sell it and upgrade to another subaru.
any help is appreciated.
mark
Thanks for the tip. I'll give that a check but think that the dealer may laugh at me..... it's a 13 year old car with 310,000 kilometres on it.
back to my first question if the recall tip doesn't work. anyone know about the interchangability of the springs?
mark
They will probably fit, but I wonder if the spring rate is the same for a sedan and a wagon. I am prett sure I have a set of springs that will fit and are off a wagon. Let me know if you want me to check for you.
