Caboobaroo Posted August 25, 2009 Share Posted August 25, 2009 Well I just had the fun weekend of swapping the suspension on my XT6. I stuck with the XT6 front knuckles since I didn't have the Impreza stuff to go into the car. So I put the Impreza struts on the XT6 knuckles and I wouldn't wish this upon my worst enemy. I got coilover sleeves off of ebay and had a set of KYB GR2s for an Impreza, spent about 2 1/2 hours a side and it was a real pain. The XT6 knuckle is about 1/16th of an inch wider then the strut. Doesn't sound like a lot but makes a lot of work to get it to fit. Had to grind down the knuckle a bit for it to barely slide onto the knuckle and after a lot of hammering, I was able to finally get it over the knuckle and bolted up. If you plan on using XT6 front parts, DON'T! Just go get the Impreza parts for the front and make it easier on yourself. Granted, you'll still need the XT6 control arms but thats all you'd need. I'm going to end up using the Impreza parts on the front end eventually but I had to do something now since both front struts were totally blown and made the ride very uncomfortable. Link to comment Share on other sites More sharing options...
Turbone Posted August 25, 2009 Share Posted August 25, 2009 Well, that sucks to hear it was a pita :-\ We've always known that you had to spread the tangs on the struts to get them to fit on a XT6 hub. I had to do it on my first XT6. You might want to get that aligned now :-p Link to comment Share on other sites More sharing options...
Numbchux Posted August 25, 2009 Share Posted August 25, 2009 I found a deepwell socket that was about 2mm wider than the XT6 knuckle. and used a hydraulic press to force it into the brackets on the impreza struts. only took me about 15 minutes a side. I used the XT6 bolts though, makes camber kind of a shot in the dark.....I had planned on putting EJ knuckles on it, before some broad totalled my baby Link to comment Share on other sites More sharing options...
idosubaru Posted August 25, 2009 Share Posted August 25, 2009 you can use a porta-power or a high-lift jack or a BFH:lol: to spread the flanges as well, that would only take a couple minutes. grinding the hub down is probably the best bet though, i'd rather do it that way as it seems better. Link to comment Share on other sites More sharing options...
Pooparu Posted August 25, 2009 Share Posted August 25, 2009 This is why I scrapped all of my XT6 stuff up front and just swapped in impreza WRX junk. Now I have a garage full of XT6 stuff. I think all I ended up using was the rear hubs and that's it. I'm going to through it all up for sale soon. I hope someone wants it. Link to comment Share on other sites More sharing options...
Turbone Posted August 25, 2009 Share Posted August 25, 2009 This is why I scrapped all of my XT6 stuff up front and just swapped in impreza WRX junk. Now I have a garage full of XT6 stuff. I think all I ended up using was the rear hubs and that's it. I'm going to through it all up for sale soon. I hope someone wants it. What did you use for lower control arms? Link to comment Share on other sites More sharing options...
Pooparu Posted August 25, 2009 Share Posted August 25, 2009 My EA81 control arms. I drilled them out to fit the ball joints. Then stuffed them with urethane bushings. (note: I did this in a 1982 Hatch) Link to comment Share on other sites More sharing options...
zukiru Posted August 26, 2009 Share Posted August 26, 2009 since it's out there. I am highly interested in your control arms.. then all I need to find are 2wd XT6 rear hubs and I'm in. Link to comment Share on other sites More sharing options...
Psyko Posted September 22, 2009 Share Posted September 22, 2009 I used a bolt with two nuts to spread the flanges wayyyy apart. Actually went together rather painlessly. Instead, my advice is to lift both sides of the car. I only had one side up and could not get my Legacy struts in because the sway bar was holding my knuckle up. Once I got the second side up, it slid right on. Link to comment Share on other sites More sharing options...
