AWD TURBO! Posted August 27, 2009 Author Share Posted August 27, 2009 wow i was stoned:slobber: but yes this is my toy yes awd... no pushbutton 4wd. awd 88 gl10 turbo wagon. Link to comment Share on other sites More sharing options...
Ricearu Posted August 27, 2009 Share Posted August 27, 2009 The definition of insanity is repeating the same thing over and over again, expecting a different result. G.T.F.O. Noob. Link to comment Share on other sites More sharing options...
Durania Posted August 27, 2009 Share Posted August 27, 2009 wow i was stoned:slobber: Yeah, your a real winner. Link to comment Share on other sites More sharing options...
subaruguru Posted August 27, 2009 Share Posted August 27, 2009 I thought i was bad... so you have a 1988 GL10 that someone swapped in a legacy transmission? IIRC the RX awd is D/R 3.7 with diff lock or S/R 3.7 no diff lock im pretty shure that was the only options but you dont have an RX so eather you have... A. single range 3.7 (NOT AWD) OR B. somone put a legacy AWD trans in. if you do have the lego trans you are half way to the ej swap because someone already used an adapter plate haha . I'm shure if i am mistaken someone will help out but thats my understanding. Rob. Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 27, 2009 Author Share Posted August 27, 2009 ok i have a 1988 subaru full time awd turbo gl10 wagon this came from dealer with single range 3.7 w lsd & with diff lock not legacy AWD trans. no adapter plate. Link to comment Share on other sites More sharing options...
7point62fmj Posted August 27, 2009 Share Posted August 27, 2009 I think if you talk to User "emernepal" he might be able to help you. You also sound like you might have alot in common. Just do a search for him by user or in the search link above. Link to comment Share on other sites More sharing options...
Niku-Sama Posted August 28, 2009 Share Posted August 28, 2009 you sure some one didnt take a '90 trans and put it in there? i'm not talkin legacy either but usually when some one comes on and says they have AWD a bunch of people are quick to correct them. i was one of those untill i said i had a '90 turbo wagon with a 1st hold button for the 4eat in it. mabe people here are wrong though and more of these wagons exist over other years but i say take a pic of the dash, that'll be the sure fire way to tell. if people swap they generally dont swap the cluster and it's different on full time models Link to comment Share on other sites More sharing options...
mudduck Posted August 28, 2009 Share Posted August 28, 2009 This thread has got my sides hurting from laughing. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 28, 2009 Share Posted August 28, 2009 88 and 89 GL turbo's were often equipped with the Full Time 4WD single range 5 speed with diff lock or the Full Time 4WD 4EAT automatic. It is NOT AWD - it is FT4WD - there is no VC, only a center diff (lockable for true 4WD in the 5 speed). If you hang one wheel off a ciff you will be stuck unless you lock the diff. Not so with AWD - hang a wheel out over a cliff (or several) and you will still drive away without locking anything. XT6's got a similar transmission but in 3.9 final drive. GD Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 28, 2009 Author Share Posted August 28, 2009 Originally Posted by WJM SUBARU Master Technician Join Date: Jan 2002 Posts: 7,731 Re: EA82T, Easy 130-140hp? (not asking for directions) --------------------------------------------------------------------------------from jwm EA82T ftw. I've had mine that fast. Easy. I had one that was putting out 240 CRANK hp and 320 CRANK tq for a LONG time. No problems. That engine still lives today after 40k+ street miles, a day at the road course, over 100 autox's and a few mountian runs. & more from this user Re: EA82T, Easy 130-140hp? (not asking for directions) -------------------------------------------------------------------------------- Quote: Originally Posted by beataru Thats All I read in that sentence... are you for real??????????????????????????? and what mods, please say none internally! Header, turbo back, STI TMIC, intake, 14 PSI of boost. I was running dry ice with sprayers so ice cold With a Air / Fuel Ratio Gauge I will be able to tune it in Link to comment Share on other sites More sharing options...
Ricearu Posted August 28, 2009 Share Posted August 28, 2009 Sell your subaru to a real subaru nut who will de-rice it and give it a good home, 1. Buy a civic, 2. buy a STOCK Integra LS B18a block with stock internals, 3. bolt a B16a head on it, 4. bolt a t3/4 turbo on it, set the wastegate to "14" PSI 5. run an untuned hondata s300 with junkyard DSM 450cc injectors 6. bolt it into the civic to a stock transmission 7. BLOW UP A CAR WE DONT GIVE A CRAP ABOUT!!! Rice out a car that nobody cares about, not a GL-10. Nobody cares how much "power" you have gotten from a EA82T at "14" PSI. If you are that bent on attaining power, please just stuff a ej257 in it an just leave it alone, instant power... NO BLOWN EA82t's. JEEEEZZZZ!!!!! My rant is done.... Link to comment Share on other sites More sharing options...
Niku-Sama Posted August 28, 2009 Share Posted August 28, 2009 grrr good thing this board hasnt gone to an autmoatic infraction system where a script on the server deems weither or not your posts viloate any thing and auto ban you for the rest of the day like they started at hybrid z. i think we'd all be ************ed Link to comment Share on other sites More sharing options...
4x4_Welder Posted August 29, 2009 Share Posted August 29, 2009 Ok, I hit fuel cut on a stock EA82T. It's not hard. Cooling has nothing to do with it. The MAF only flows enough air to support 115-120hp, more and -you guessed it- the computer flips out and stops giving it fuel. Not to mention that with the archaic PCV system of the EA82T, you WILL pop your rear main seal out. Ask me how I know this- BTW, you stated the reason you kept up with the WRX- He didn't know you were there. It's hard to race an unknown opponent, he probably realized you were there at about 70mph, waited for the lag to go away and left you in the dust before you could hit 80. Also, I'd like a clarification on your "dry ice sprayers"- How do you spray dry ice? Do you shoot the Co2 straight into your intake? Do you use it to chill water to -109º? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 29, 2009 Share Posted August 29, 2009 you WILL pop your rear main seal out. Ask me how I know this Some Loctite on the OD of the seal will stop that. Doesn't help if you have never replaced the original seal though... GD Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 29, 2009 Author Share Posted August 29, 2009 (edited) Ok, I hit fuel cut on a stock EA82T. It's not hard. Cooling has nothing to do with it.The MAF only flows enough air to support 115-120hp, more and -you guessed it- the computer flips out and stops giving it fuel. Not to mention that with the archaic PCV system of the EA82T, you WILL pop your rear main seal out. Ask me how I know this- BTW, you stated the reason you kept up with the WRX- He didn't know you were there. It's hard to race an unknown opponent, he probably realized you were there at about 70mph, waited for the lag to go away and left you in the dust before you could hit 80. Also, I'd like a clarification on your "dry ice sprayers"- How do you spray dry ice? Do you shoot the Co2 straight into your intake? Do you use it to chill water to -109º? Well first off I have hit I hit fuel cut but I don’t any more after I put the new intercooler on The archaic PCV system it’s fixed I am not boosting the crank case The dry ice was on the center of the intercooler The water sprayers going on the sides & no the co2 off the ice is not going in the intake & that would be called ice at that timp o and this is not a stock EA82T 2 1/2 Mandrel Bend Exhaust this is the link to the intercooler http://www.cxracing.com/mm5/merchant.mvc?Screen=PROD&Store_Code=CXR&Product_Code=IC004-BOV017-FLANGE-Y-PIPE&Category_Code=ICKSB Edited August 29, 2009 by AWD TURBO! Link to comment Share on other sites More sharing options...
Myxalplyx Posted August 29, 2009 Share Posted August 29, 2009 (edited) I will chime in! It is easy to see how this thread started to derail. Can you post any pics of your car? Engine bay pics would be nice. Is anyone here near the poster? Could you perhaps try to give him some face-to-face guidance or get some input from him face-to-face? You never know what you can find from a fresh mind and face that is doing the same things some of us have already done. I still like the EA82T ONLY because I have had positive experience with gaining hp/torque from it. Never got a chance to raise the boost on it but it ran great until the suspension rusted itself to death. Without turning up the boost, power gains were about 35whp if I remember correctly, or damn close. AWD Turbo.....all I can recommend for now is to IMMEDIATELY turn down your boost to stock psi. Invest in some gauges to monitor your exhaust gas temperature and air/fuel ratio (Mainly the temperature). Be sure things are 'cool' and slowly turn up your boost in increments of 1-2psi, while monitoring exhaust gas temperature. Edited August 29, 2009 by Myxalplyx Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 29, 2009 Author Share Posted August 29, 2009 (edited) Well thanks 4 the input but the motor that is in it now has been rebuilt It does 15 psi w/o ping or fuel cut I am using 92 with octane buster I know but I am not going to turn down my boost the motor is 10 mo old The new one is on the stand waiting 4 its turn The egt would be good thing to put back in The top egt I have had was 700f This was the one that had the bad lifters & the picks I will try to find my camera & post them win I do My daughter put it some ware can’t find it i use this as my toy! Edited August 29, 2009 by AWD TURBO! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 29, 2009 Share Posted August 29, 2009 The top egt I have had was 700f That's very low. I would question both your gauge and sending unit placement. It is not unusual to see 1100* or 1200* F on turbo engines when under boost. I had my digital temp gauge on my EA81 non-turbo and it ran 500* - 600* F at idle. GD Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 29, 2009 Author Share Posted August 29, 2009 grate now i need a new egt!!! Link to comment Share on other sites More sharing options...
Myxalplyx Posted August 29, 2009 Share Posted August 29, 2009 Where is your location? Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 30, 2009 Author Share Posted August 30, 2009 vancouver wa Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 30, 2009 Author Share Posted August 30, 2009 (edited) [attach]6827[/attach] [attach]6828[/attach] [attach]6829[/attach] Edited August 30, 2009 by AWD TURBO! Link to comment Share on other sites More sharing options...
rxleone Posted August 30, 2009 Share Posted August 30, 2009 Um....So the grey one is the car? I'd be focusing more on the exterior of the vehicle then absolute performance bud. To be honest, it looks pretty whorey. Link to comment Share on other sites More sharing options...
AWD TURBO! Posted August 30, 2009 Author Share Posted August 30, 2009 (edited) [url=http://www.ultimatesubaru.org/forum/showthread.php?t=27730][/url] Um....So the grey one is the car? I'd be focusing more on the exterior of the vehicle then absolute performance bud. To be honest, it looks pretty whorey. Why I am not in it 4 looks & do you see the toyota i use this as my play toy! The red one "was" the parts car [ATTACH]6830[/ATTACH] [ATTACH]6831[/ATTACH] [ATTACH]6833[/ATTACH] i found a good post on How much power can EA82T stand http://www.ultimatesubaru.org/forum/showthread.php?t=27730 Edited August 30, 2009 by AWD TURBO! Link to comment Share on other sites More sharing options...
