Txakura Posted August 27, 2009 Share Posted August 27, 2009 anyone made a stand to run an engine outside the car? it might be useful to run an ej from the bone yard before I get it all the way into my ea car... I'd rather waste some time messing around outside the car rather than find a monster leak or dead cylinder etc etc and have to pull it out for a $5 seal Link to comment Share on other sites More sharing options...
Legacy777 Posted August 27, 2009 Share Posted August 27, 2009 If you do all the routine seal stuff on the ej motors, they should be fine. What parts/seals are you looking to replace before you stick it in your ea? Link to comment Share on other sites More sharing options...
Txakura Posted August 28, 2009 Author Share Posted August 28, 2009 I have no ej, I just want to be able to run one before I install it and thought someone here might have had the same idea, or deals in enough engines they made something for themselves... Link to comment Share on other sites More sharing options...
davebugs Posted August 28, 2009 Share Posted August 28, 2009 Thought about it. Used to do this with the air-cooled VW's - simpler engines, electroincs, no coolant all made it easier. If someone has a rig I'd love to see pics. I scrap cars often enough I could come up with the parts easy enough. Size and simplicity would be the issues. Link to comment Share on other sites More sharing options...
Txakura Posted August 28, 2009 Author Share Posted August 28, 2009 there we go, that's what I'm talking about I used rolling stands on small aircraft engines, same thing, no coolant, lots simpler Link to comment Share on other sites More sharing options...
markjw Posted August 30, 2009 Share Posted August 30, 2009 anyone made a stand to run an engine outside the QUOTE] I modified the front 1/3 rd section of a f250 frame to test run Fe motors before install. Maybe a donor ea/ej car and a sawzall could be made to do the same. I don't know how much of the front of the car could be cut away before the chassis became too unstable. But,of course, the more you can remove,(i.e. fenders,core support),the easier it would be to work with. Link to comment Share on other sites More sharing options...
STI_Wolf Posted September 6, 2009 Share Posted September 6, 2009 ive been looking into making one for myself. at least to be able to test EA series engines. maybee we could work together and make a few of them.. i have alot of steel lying around and a couple regular engine stands, i just dont know where to begin really.. i think if a few of us joined forces we could slap a couple together in no time. Link to comment Share on other sites More sharing options...
Txakura Posted September 9, 2009 Author Share Posted September 9, 2009 almost be worth it to make a floater that wandered around to members that wanted to use it... Link to comment Share on other sites More sharing options...
subaruguru Posted September 9, 2009 Share Posted September 9, 2009 talk to bratsrus1 he made one pretty simble job but it worked even had a key start. Rob. Link to comment Share on other sites More sharing options...
ShawnW Posted September 12, 2009 Share Posted September 12, 2009 Honestly as easy as they are to remove and install the car is almost as good a test stand as any. With no radiator in it theres a lot of room. Link to comment Share on other sites More sharing options...
markjw Posted September 12, 2009 Share Posted September 12, 2009 Honestly as easy as they are to remove and install the car is almost as good a test stand as any. With no radiator in it theres a lot of room. Probably why I haven't made one. I don't even put a engine hoist on them anymore so long as my brother is around. We just lift um by hand. For now,at least. Link to comment Share on other sites More sharing options...
