Fan clutch need used one
I have a 94 loyale wagon with a/c and the clutch fan spins free with no resistence even when almost in the red. The electric fan operates properly with the a/c but gets no help from the belt driven fan thus running higher than normal temps. Without air on the temps rise when doing hills. There is no subes in junk yards in my area any ideas on where to find a good used fan clutch ? Is ther a way to hotwire the electric fan till I locate fan clutch? Thanks
i think if i remember correctly you can hotwire the fan by unplugging that radiator sensor down by the electric fan and jumpping the connectors on the harness side.
PO did this and they took an old sensor and chopped the connector off and soldered the 2 wires together on the connector and plugged it into the harness.
if you hack up an old sensor it makes it easy to un hook it and put everything back to normal
