Wow, big service and great results!
I have a 2004 subaru leagcy 35th anniversary edtion sedan with about 43k on it and had a huge service done on it and it runs even better than it did, here is what I had done.
oil and filter change
exterior wash and wax
replaced front v belts
flushed the brake system and abs system and installed new fluid
cleaned and flushed my transmission and torque convertor and installed new fluid
had a power steering fluid cleanout including the g pump and pinion lines and new fluid installed.
had a fuel induction service done to which made the car run so much better, what a difference
coolant wasnt needed since I had to have a new shortblock replaced from bad piston slap, and my plugs and wires were ok to, rear diff fluid also ok at this time but but next service I will have it replaced by my request. So other than that I am very happy with the whole service!
