EA82t upgrades
yes and probably an air/fuel gauge too.
Wideband - those narrow-band gauges are gimmicks. They won't tell you anything useful for a turbocharged engine. Anytime you are under boost you will be off-the-chart rich on those gauges. They are good only for people that want to try and maximize their mileage by staying in the stoich sweet spot. Do that on your turbo and you'll be looking for a new engine after you head over to the next county to collect your pistons and rods.
this one is an experiment and is set up like a factory boost control. It has a two way solenoid when off there is no boost modification when on there is a bleed to raise boost to a preset level. the default setting is closed and stock boost. I went this route because I didn't trust the solenoid to control the wastegate directly.
