Mr. Carb Posted January 29, 2004 Share Posted January 29, 2004 Well, I got it all together, Everything's streight and fixed... and mounts... http://usmb.net/gallery/album107 check out the newest album, it has pictures from today after I completly assembled it. Everythings bolted on! However, I ran into a new problem. When it runs for a good 20 minutes... the oil pressure runs 50psi-75psi (runs into the 75psi range when throttle hits 1,500 or higher) Suddenly drops to 0psi... and then the engine kinda makes a low rumble kinda soft clunking sound, when it idles... now if it was a shot oil pump, I was thinking it wouldn't work at all.... Anyone have any ideas what it might be? Any info is as always much apriciated. Thanks Link to comment Share on other sites More sharing options...
Mr. Carb Posted January 29, 2004 Author Share Posted January 29, 2004 bump? Link to comment Share on other sites More sharing options...
Nug Posted January 29, 2004 Share Posted January 29, 2004 Oil pressure regulator? Link to comment Share on other sites More sharing options...
ShawnW Posted January 29, 2004 Share Posted January 29, 2004 Dare I say there isn't any oil in the motor? Link to comment Share on other sites More sharing options...
edalexandr Posted January 29, 2004 Share Posted January 29, 2004 do you have the right amount>? if it is low the higer rpms it my be sucking air just my thought Link to comment Share on other sites More sharing options...
junkyardgabe Posted January 29, 2004 Share Posted January 29, 2004 try changing your oil cheap and quick Link to comment Share on other sites More sharing options...
SuperRallyRoo Posted January 29, 2004 Share Posted January 29, 2004 They just put the motor in a little while ago I watched them put oil in it. Link to comment Share on other sites More sharing options...
Mr. Carb Posted January 29, 2004 Author Share Posted January 29, 2004 Well actually it has just barely a little to much oil in it, it's about an 8th inch past the full mark on the dip stick. so theres an oil pressure regulator in there someware? Link to comment Share on other sites More sharing options...
Mr. Carb Posted January 29, 2004 Author Share Posted January 29, 2004 Also if I rev the engine up to about 3,000 rpms, the oil pressure does barely lift off of zero, barely..... it gets no where near 25psi. Link to comment Share on other sites More sharing options...
