tightening screws on back of oil pump
Are you just supposed to tighten them and not use any of the anerobic sealant (not the oil pump to block--I am talking about the plate on the back of the oil pump)
Also...how tight? There is no wway to measue the torque---should I use my impact (manual) driver and a hammer to set them home?
I make them about as tight as I can with a conventional screw driver.
Sometimes other folks and I loctite them. Think about how clean Loctite really needs the surfaces to be to work though. I'm undecided if it's a good practice. I rarely have the time to properly clean and wait for the oil pump to dry (like overnight) before re-assembly. In truth I rarely Loctite them - only if a screw or two is really, really loose do I do this to it(them).
I figure I'm torqueing them down more than the factory did and that should help avoid future problems.
Hopefully others will comment.
