Markus56 Posted August 31, 2009 Share Posted August 31, 2009 So, here goes another (the same) problem with my wagon. Still won't run right after doing a weber swap. It ran ok before on the hitachi. Then I ran into some problems with it not wanting to run. Took it to a shop where they informed me that it had a vacuum leak somewhere and that they would rebuild it for 300 bucks. Instead they turned up the idle, so that it wouldn't die on me. So i ran it like that for about 6 months before i finally had all the stuff i needed to do the weber swap. It hasn't run right since. Is there a good write up somewhere (with pictures) so i could go back over my work and check to make sure i did everything right? http://www.ultimatesubaru.org/forum/showthread.php?t=75986 this link doesnt work http://www.ultimatesubaru.org/forum/showthread.php?t=49931 and this one doesn't have pictures and if anyone has any ideas, or an insurance claim and napalm, feel free to mock me in my despair Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 31, 2009 Share Posted August 31, 2009 So what problems are you having with the Weber? GD Link to comment Share on other sites More sharing options...
Markus56 Posted August 31, 2009 Author Share Posted August 31, 2009 It won't idle. It either runs at 2000 rpm or higher, or it doesnt run at all. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 31, 2009 Share Posted August 31, 2009 It won't idle. It either runs at 2000 rpm or higher, or it doesnt run at all. Used Weber or brand new? I would say you have a good sized vacuum leak or a clogged idle jet. GD Link to comment Share on other sites More sharing options...
Markus56 Posted August 31, 2009 Author Share Posted August 31, 2009 (edited) It's freshly rebuilt with new jets, so it's gotta be a vacuum leak. I just don't know where. I sprayed the base of the carb with brake cleaner and nothing happened. If someone could point out the major leak areas, it would be appreciated! Edited August 31, 2009 by Markus56 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 1, 2009 Share Posted September 1, 2009 Never rule out a clog - pull the idle jet and inspect the tip for blockage. They are very small and I've had them clog on me whiile off-roading. Fortunately they are right on the front of the carb and easily accesible with just a flat blade screwdriver. GD Link to comment Share on other sites More sharing options...
Uncle Ed Posted September 1, 2009 Share Posted September 1, 2009 (edited) You said you had the same problem w/other carb on it. Another thought, have you checked for a vacuum leak where the intake bolts to the heads? Your sure you've capped off all the un-needed ports on the manifold? What about the EGR gasket or the EGR valve, when was it cleaned? Not mocking you, just double checking your trouble shooting as its easy to over look something. Ed Edited September 1, 2009 by Uncle Ed Link to comment Share on other sites More sharing options...
