Announcements
Red Sedan Build , solid rear axle
Scott in Bellingham
  Flowmastered87GL said:
I agree, some people pay good money for those bullet hole stickers... you got em bigger and for free! :banana:
Funny you should bring this up, I don't understand the reason people put those sticker on there vehicles? To me its dumb, Does it make you tuff and ghetto or what? Just like all the prisom tape, WHY!!?? :-\
Lol
-Tom :)
  • Replies 249
  • Created
  • Last Reply
Top Posters In This Topic
Can't find the beater 'Yota, but these might be of interest
http://bellingham.craigslist.org/pts/1377626362.html
The axles on this are fullsize, but cheap
http://bellingham.craigslist.org/cto/1374710270.html
And some Jeeps. I don't know about track width, but I'm sure they could work
http://bellingham.craigslist.org/cto/1368633451.html
http://bellingham.craigslist.org/cto/1352362543.html
Can't remember if this generation of Trooper has a solid front axle or not, but here's a possibility
http://bellingham.craigslist.org/cto/1374758360.html
Edited by jg09
I do believe the '90 Troopers still had a full axle (Not independent) I know I've seen Troopers up till '93 that still used the full axle.
Also, whats the diffrence between a front or rear solid axle? Besides the pumkin being at an off set on some. So why couldn't you use a rear axle in front, and just modify the housing for whats needed?
Just my thoughts
-Tom :)
Just my thoughts
-Tom :)
the front needs the ability to turn :)
the toyota 3rd members are interchangeable front to rear....
  McBrat said:
how's the diff clearance with the gas tank? be sure to put some bump stops in :)
it clears even with the 31s stuffed all the way up, not much room for upper arms ., just might get some work done on it today , trying to decide if to stick with the subaru front end or solid axle it, leaning towards the suby stuff as I already have it and like the lite nimbleness , I guess if in the futre I wanted a solid axle up front I could always change it out , and i already have a nissan 720 t-case , its raining today good day to be in the shop
OMG duh! Geez, strike that I said that. well I've had a feaver and a head cold for the last few days (Not in my right mind)
Scott, I would just stick with the subie diff and see how you like it (You can always change it out at latter date)
-Tom :)
  The Beast I Drive said:
I am running 31" tires with an EA81 and it works just fine, and Im still using the stock Subaru drivetrain, no T-case. Its a little gutless on steep hills, but with the extra gears you have that wont be a problem.
-Bill
Do we really need to run 31s? ;)
  Scott in Bellingham said:
got the frontend bolted up ended up doing a 8" lift and brought forward 2"
next install dual range and engine looks like EA81s going in , just have to swap out the fuel pump for a carb , going in today :banana:
Nice, are you going with a weber right away?
-Tom
