Scott in Bellingham Posted January 9, 2010 Author Share Posted January 9, 2010 been lookin at the car and lookin at different options, pros and cons heres a list............................................................................2nd tranfer case Lower gears,weaker front diff studs because Im using a rear Diff Higher center of gravity as the engine and transaxle would be in stock height more weight with 2nd transfercase and frame to mount it,also second crossmember for engine support and 3 drive shafts instead of 1 keep stock transaxle................. lower center gravity , better clearence mid car, less of a aproach angle , less weight, less parts, less engineering, only one driveshaft to have made not 2 Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 10, 2010 Author Share Posted January 10, 2010 got the car moved today, its now back it the corner all so started some major cleanup found the back wall of the shop, its been 10 years since I saw that area, moved the new to me bandsaw in place , moved the wood stove out next for a steel rack on the back wall Link to comment Share on other sites More sharing options...
monstaru Posted January 10, 2010 Share Posted January 10, 2010 you have stayed "easy" for the last few cars..:lol:come on scott..:grin:cheers, brian Link to comment Share on other sites More sharing options...
Uberoo Posted January 10, 2010 Share Posted January 10, 2010 If I may make a suggestion: Lower the T case an inch or so.The input drive shaft looks to be at a bit to steep of an angle for reliable power delivery.From what ive heard a 5-10* angle on the drive shaft is about all thats practical before it starts binding up.10* of free standing angle is a bit extreme for U joints.It may work but it would probally wear out really fast. On the other hand,the U joint is just spinning with no up or down travel so it might work...Again I don't know how long U joints will last. Link to comment Share on other sites More sharing options...
mcbrat Posted January 10, 2010 Share Posted January 10, 2010 Scott in Bellingham said: been lookin at the car and lookin at different options, pros and cons heres a list............................................................................2nd tranfer case Lower gears,weaker front diff studs because Im using a rear Diff Higher center of gravity as the engine and transaxle would be in stock height more weight with 2nd transfercase and frame to mount it,also second crossmember for engine support and 3 drive shafts instead of 1keep stock transaxle................. lower center gravity , better clearence mid car, less of a aproach angle , less weight, less parts, less engineering, only one driveshaft to have made not 2 if you just go solid in the rear without a t-case (keep stock transaxle) as front wheel drivers, unless you lock it, you are still going to be limited to doing the same things a regular lifted soob with a welded rear does... I originally thought I'd keep the stock fuel tank, but it's have to sit so high to do so, you lose your low center of gravity advantage... When Chris designed mine, it was basically, set the ride height and then engineer the stuff around it so it will work at that height... another guy in my club has a jeep with 35's under it, not sure how much lift, but I'me a good 12" shorter than he is (top of vehicle). a lot of that is inherent in the design of the soob body, but it helps... I can still duck under trees pretty well.... Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 11, 2010 Author Share Posted January 11, 2010 monstaru said: you have stayed "easy" for the last few cars..:lol:come on scott..:grin:cheers, brian EASY you dont remember that silver car that saved your ( Dodge) 2-1/2 years ago??, that thing wasnt "easy" has a 2nd tranny and transfercase , 9" lift and modified body, come on Brian Ill challenge you to a build off and we will meet up this summer and compete our 2 soobies side by side and see what happens , I realy like my ole white car just want somthin a little better that will not break Link to comment Share on other sites More sharing options...
SoobieDoo Posted January 11, 2010 Share Posted January 11, 2010 Build off!?! A little "friendly" competition never hurts. Link to comment Share on other sites More sharing options...
Breeke Posted January 11, 2010 Share Posted January 11, 2010 BUILD OFF!! BUILD OFF!! (chanting) Link to comment Share on other sites More sharing options...
monstaru Posted January 11, 2010 Share Posted January 11, 2010 oh, i'm not really into competition......and you have more space and resource than i do.I know you are a competent builder scott.and really, if you think about it...that car would be easy to build again,because you have already done it once:)and i said for th elast few cars,(yours or not) i was just responding to "giving up eaayy?":lol: cheers, brian oh, and by the way, as long as it is FRIENDLY competition...i'll think about it. Scott in Bellingham said: EASY you dont remember that silver car that saved your ( Dodge) 2-1/2 years ago??, that thing wasnt "easy" has a 2nd tranny and transfercase , 9" lift and modified body, come on Brian Ill challenge you to a build off and we will meet up this summer and compete our 2 soobies side by side and see what happens , I realy like my ole white car just want somthin a little better that will not break Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 14, 2010 Author Share Posted January 14, 2010 (edited) Scott in Bellingham said: been lookin at the car and lookin at different options, pros and cons heres a list............................................................................2nd tranfer case Lower gears,weaker front diff studs because Im using a rear Diff Higher center of gravity as the engine and transaxle would be in stock height more weight with 2nd transfercase and frame to mount it,also second crossmember for engine support and 3 drive shafts instead of 1keep stock transaxle................. lower center gravity , better clearence mid car, less of a aproach angle , less weight, less parts, less engineering, only one driveshaft to have made not 2 OK decided which direction to go, I didnt really like the Nissan case its so tall and would need a framework to mount up , so I went out and picked up a Toyota 86 4runner 4x4 tranny with transfercase , checked it out tonight Heres the Subaru clutch disc next to the Toyota one, the Toyota one has a bigger hole with more splines , subarus on the right, also the subby preasure plate has a larger throwout bearing and "hole" subbie center bearing slipped onto the Toyota pilot same size... Edited January 14, 2010 by Scott in Bellingham Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 14, 2010 Author Share Posted January 14, 2010 Heres the EJ Flywheel heres the EJ trannywill need to cut the front off the tranny machine it down , cut the Toyota Bell housing in half Machine it down and weld the 2 halves together Link to comment Share on other sites More sharing options...
Numbchux Posted January 14, 2010 Share Posted January 14, 2010 very cool idea! can't wait to see the result of this! maybe throw some 4.7:1 gears in that tcase while it's out. Link to comment Share on other sites More sharing options...
NinjaTech Posted January 14, 2010 Share Posted January 14, 2010 So are you planning on using the Toyota clutch disc with the subaru flywheel and pressure plate? Also, will you be doing the welding on the bellhousing? I've heard from the TIG guys in my class that cast aluminum is a real pain to weld. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 14, 2010 Author Share Posted January 14, 2010 NinjaTech said: So are you planning on using the Toyota clutch disc with the subaru flywheel and pressure plate? Also, will you be doing the welding on the bellhousing? I've heard from the TIG guys in my class that cast aluminum is a real pain to weld. yes and yes Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 14, 2010 Share Posted January 14, 2010 Yes very cool. And i have 4.7:1 gears in my 4runner, i bet it would be ***************in in a subaru! Link to comment Share on other sites More sharing options...
TheLoyale Posted January 14, 2010 Share Posted January 14, 2010 Cool updates! Its coming along quite nicely. C'mon 4.7:1 gearing!! -TJD Link to comment Share on other sites More sharing options...
NinjaTech Posted January 14, 2010 Share Posted January 14, 2010 Scott in Bellingham said: yes and yes awesome. Are you going to be using TIG or a MIG with a spool gun? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 14, 2010 Author Share Posted January 14, 2010 ninjatech said: awesome. Are you going to be using tig or a mig with a spool gun? tig Link to comment Share on other sites More sharing options...
capn_r Posted January 16, 2010 Share Posted January 16, 2010 How about the possibility of using the bellhousing portion of an EJ automatic? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 19, 2010 Author Share Posted January 19, 2010 capn_r said: How about the possibility of using the bellhousing portion of an EJ automatic? I got one its deeper then the toyota, and positions the starter back farther, maybe would work with a automatic starter not sure Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted February 1, 2010 Author Share Posted February 1, 2010 heres what Ive been thinkin for the rear flexizer , just a little mockup I did on a old Datsun model Link to comment Share on other sites More sharing options...
SoobieDoo Posted February 1, 2010 Share Posted February 1, 2010 We need more subaru models, eh!?! What kind of struts would you use with that setup? I assume they would be the only factor limiting flex. Link to comment Share on other sites More sharing options...
monstaru Posted February 2, 2010 Share Posted February 2, 2010 thats crap.......how are you even going to fit in the model?cheers, brian Link to comment Share on other sites More sharing options...
baccaruda Posted February 2, 2010 Share Posted February 2, 2010 Those tires will get you into the mud, but not out! Link to comment Share on other sites More sharing options...
mcbrat Posted February 3, 2010 Share Posted February 3, 2010 Scott in Bellingham said: heres what Ive been thinkin for the rear flexizer , just a little mockup I did on a old Datsun model if you don't move your fuel tank, that'll make you sit pretty high.... some good info.... http://www.alaska4x4network.com/showthread.php?t=25022 Link to comment Share on other sites More sharing options...
