Announcements
Red Sedan Build , solid rear axle
Scott in Bellingham
  • Replies 249
  • Created
  • Last Reply
Top Posters In This Topic
You could probably run a FWD 5spd end cover and shifter, you don't need the transfer assembly anymore and the d/r part is in the front of the case. That would shorten up the tranny under your knees.
FWD fivespeeds are totally different. Shift rod in a different spot in the case.
You can't just put a FWD cap on the end of the 4wd Trans. The lower shaft is way to long.
Interesting for sure. I hope that front diff on the d/r holds.
me too, its turning a 4.1 diff so there should be less stress on it and if anything give seems like it would be the rear drive axle/driveshaft on the D/R
last night I removed and axle off the Toyota Taco Rear the wheel bearing was shot, Ive never had one apart, figured out how it went, I checked an old 2WD rear I had and to my wonderful surprize the bearing and housing were the same so I swappped them out with the help of a press and now I have good wheel bearings WOOO hOO ,
tonight I removed the Diff and welded it up , so were gettin ready , will be takin it out on the 16th of Oct to walker
  • 9 months later...
puttin the engine back up front
got the engine back up front in stock location,
hereswhere it used to live
transfercase in position
anyone know what all this means?
just bought a set of Yota axles they both have 5.29s, front has a ARB air locker and rear has a lockrite
Edited by Scott in Bellingham
pics
  • 3 weeks later...
got my axles
Toyotas 5.29 gears, lockright in the rear , ARB air locker up front, front axle will wait a while, I realy need to get this this back on the trail, this time around it will be driven not trailered to the trail, got the front diff redone its a 4.44 with old style diff stub carrier
old setup out
will keep the same rear spring and pivot
finally moves under own power
things left to do to make usable
hook up rear brakes
rear shocks
exhast
more to come
rear sheetmetel work
rear trunk lid
tidy up interior
external rollcage
winch front and rear
air cylinders on rear axle to control movement
later yet
add toyota front axle and a set of NEW tires
  • 1 year later...
  • 2 months later...
little update, took this thing out a year ago , it has super low rear gears,goes good I like the rear flopper , well I changed  out now I can run all same tires, I sold the yota front axle as it wasnt going to be easy ettin it all set up, also that dana 20 t-case howls leaks anf grunts so that things out and looks like Ill put a nissan case in there as it lines up well with the subbie diff, we will see
