Announcements
Red Sedan Build , solid rear axle
Scott in Bellingham
  • Replies 249
  • Created
  • Last Reply
Top Posters In This Topic
I'd put in one of your carbed EJ22's with a EJ 5spd. Weld the center differential and use the rear output for the transfer case. The lack of low range in the tranny will be made up for by the transfer case and the extra power of the EJ will help.
I <3 this plan :grin:
Quick question, did the 1600 have the side mount starter? If it did, how much would you want for that motor?
-Bill
it was in a wagon with dual range , yes side mount , I didnt know till I saw the flywheel with a smaller clutch and decided to install a bigger one but the crank bolt pattern was smaller , $200 sound fair ?
pretty sick build going on.
one question, it looks like that diff is mounted right side up... doesn't it need to be upside down to spin the right way?
does the t-case you're using going to correct that issue?
yes, the t-cae takes care of the spin direction so the diff just get's mounted as normal...
Must be nice to be taking your time on this one...after that duner module build! I assume it'll be winched, so any bumper plans yet? Maybe the silver tank's, if it's not too heavy. :)
Im designing a single 3" tube bumper, somethig we can start making for the masses, going to go look at a toyota tacoma rear axle see how wide it is may get it think its a 4.10
A neighbor of mine has a skateboard slide about that size that I've been eyeballing. zzz
Isn't there a soob center diff that's a 1.1 ratio? Using that would get you pretty close to 4.10
Measured the Toyota tacoma rearend its 60-1/2" wide , looks like the subaru rear EA82 is 60" so Im going to get it, its a 4.10 ratio so that will work with the 4.11 up front and then I will be able to use same rims and tires front and rear and the datsun truck rearend was like only 55 " wide , so it keeps evolving, set the transfercase under the car , its a tall hummer, looks like I will be cuttting the tranny tunnel out and raise it up a few inches would like the t-case up another 6"
Edited by Scott in Bellingham
detail
that why I ended up selling mine.
yep, the option here is zuki..........something you can flatbelly.....as much as possible.and remember with the rear that you will have to have a splined driveline to extend with the axle.cheers,brian
Edited by monstaru
the other advantage to the zuki is it has a reduction in the high-range as well (I think, correct me if I'm wrong....). which is a big help with a little soob 4-cyl and big tires.
correct. :banana: the high range in the sammy case is 1.4:1 reduction, and when combined with th Toyota 4.10 axle gears, allows me to use 5th gear on the interstate with my 35" tires... better than I could with the stock soobie drive train, and 27" SSRs... :brow: with the soob in HI as well....
This is gettin' good. :popcorn: (could you expect anything else from an SJR build?)
I've talked to the guy that has the John Deere Brat from WCSS10.
He's doing a Zuki case and cut the tunnel to clear it with the trans in the stock location.
Says the sheetmetal surrounding it will make a nice arm rest. And it's tucked up in with the body. Nothing hanging down. :)
