glcoupeguy Posted September 5, 2009 Share Posted September 5, 2009 so i pulled the fuel line hose to replace it and realized i had bought the wrong size. i put it back on and lost oil pressure... i was pissed because an oil pump on an EA82 is 150 bucks. i decided to start the car today and i had pressure! bad news is i went ahead and replaced the hose and lost pressure again. im confused. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 5, 2009 Share Posted September 5, 2009 The gauge and sending unit are electrically coupled. Chances are you just found a wireing short or loose connection while you were changing the hose. GD Link to comment Share on other sites More sharing options...
glcoupeguy Posted September 5, 2009 Author Share Posted September 5, 2009 i also replaced a vacuum hose and fuel return line as they were all showing signs of wear. i didnt touch any wiring and the oil pump sensor is on the other side. could air in the fuel line cause the ecu to function improperly? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 5, 2009 Share Posted September 5, 2009 ECU has nothing to do with the oil pressure gauge. GD Link to comment Share on other sites More sharing options...
