owtbak Posted September 6, 2009 Share Posted September 6, 2009 I have a '97 legacy outback wagon with a '96 ej22 swapped into it. It has a forester auto tranny swap from same gen. Anyone know how many quarts this tranny holds? I've heard 4 to 5 quarts, but i just want to confirm. i'm looking to flush and refill the tranny fluid. thanks in advance! Link to comment Share on other sites More sharing options...
wtdash Posted September 6, 2009 Share Posted September 6, 2009 I have a '97 legacy outback wagon with a '96 ej22 swapped into it. It has aforester auto tranny swap from same gen. Anyone know how many quarts this tranny holds? I've heard 4 to 5 quarts, but i just want to confirm. i'm looking to flush and refill the tranny fluid. thanks in advance! Hello, Found this ONLINE for a '95 Legacy - yours should be very similar: Automatic Transmision: Fluid capacity - 8.4 US qt SEARCH on here on about flushing/replacing the tranny fluid if the tranny is a 'high miler'. Also, it takes 3-4 drain/refills to replace all the fluid. The engine holds 4-5 quarts of oil. GL, TD Link to comment Share on other sites More sharing options...
OB99W Posted September 6, 2009 Share Posted September 6, 2009 Depending on whether the car is level, etc., draining via the pan plug will remove about 4 quarts. Full capacity is about 9-10 quarts. Even a single draining and refilling of the pan will replenish the fluid to some degree, but depending on the fluid condition anything up to a complete flush might be the better thing to do. Here are a couple of links that could help you decide what to do: http://www.ultimatesubaru.org/forum/showthread.php?t=80098 http://www.ultimatesubaru.org/forum/showpost.php?p=621866 Link to comment Share on other sites More sharing options...
owtbak Posted September 6, 2009 Author Share Posted September 6, 2009 thanks guys, links were very infomative. i think i'll just do the drain and fill 2 or 3 times. Link to comment Share on other sites More sharing options...
