September 6, 200916 yr First let me say I know this would prob be a better posting on NASIOC or ClubWRX or something so I will prob post there also.. anyways...My 02 WRX is tuned OS with Romraider. When I go to try and adjust the target boost table the max boost PSI I can increase to is 24.75 PSI...why is this? Do they figure anything above this you should prob go with a standalone? Is there a user setting I can override/change? I have searched the net for the answer and so far came up dry. Just thought I would throw this Q out there... Thanks in advance..Any insight would def. be appreciated...
September 6, 200916 yr Can you even boost past 24psi? lol. Like if the wastegate is kept closed solid till near redline. I doubt the wastegate can hold anything over 24psi to begin with.
September 6, 200916 yr Author yea..lol..Its a fully built 2.5 STI hybrid motor with a GT32...I have a 46mm Tial EWG lol..Just trying to tweak it up to maybe 27-28 PSI and I'm stuck..The wastegate tables are adjusted where I 'd like them so all i really have left is boost..lol..
