BRATDUDE Posted September 7, 2009 Share Posted September 7, 2009 I purchase this car that was wrecked, a 2003 forester. I changed the abs actuator, unplugged the main electrical connection. I bled all lines and made sure everything is back in place as before,now the light on the abs is on. How can i get it off? Link to comment Share on other sites More sharing options...
nipper Posted September 7, 2009 Share Posted September 7, 2009 Do a search here on Antilock brakes and something should come up on how to read the codes. Why did you replace all those parts? Odds are a wheel sensor is eroded and giving a bad wheel speed reading or a broken tone ring. nipper Link to comment Share on other sites More sharing options...
john in KY Posted September 7, 2009 Share Posted September 7, 2009 +1 for a cracked tone ring. Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 7, 2009 Author Share Posted September 7, 2009 Thanks for the reply. This forester was hit in the right side, it hit the actuator and moved it out of it holder. I thoguht it would be best to do the exchange while i had it apart. I had a 2004 that i am using parts from. I am a decent mechanic, but what are you refering to as the tone ring? All of my fluids are normal, no leaking. I am here in fl, with no rust or salt, so the sensors shoud be ok. But who knows. Any help i would appreciate. By the way, i can pull a ob check for the engine, how can i check for the abs light, i know there is another plug under the dash beside the obs connection. What is this for, anyone know> thanks again Link to comment Share on other sites More sharing options...
