chadwick35/04 Posted September 8, 2009 Share Posted September 8, 2009 Last night I was on the highway in ny and getting my spring water and was on a long stretch of highway so I decided to use my cruise control, so I turned on the switch to the left and pushed the bar on my steerting wheel to set it and it would not work, so I turned it off and then retryed it and it still won't work, any ideas on this? No check engine light on either that will make it stop anyways cause I have a 04 legacy, car is going to the dealer tomorrow anyways cause I still have my extened warranty, and it should be covered considering I have a good plan I chose.:-\ Link to comment Share on other sites More sharing options...
bheinen74 Posted September 8, 2009 Share Posted September 8, 2009 i would doubt warranty will cover it. Cruise is not required for the car to run, drive etc. Its a non needed device and likely not covered. Link to comment Share on other sites More sharing options...
Rooster2 Posted September 8, 2009 Share Posted September 8, 2009 First thing I would do, is to check the fuse. On my cruise, I have to hold down the "set bar" for a second or two for it to lock in. I can hear a little click from under the dash that I have learned is an audible indicator that the cruise has engaged. Link to comment Share on other sites More sharing options...
nipper Posted September 8, 2009 Share Posted September 8, 2009 98% of the time it is a bad switch on the brake pedal and/or clutch pedal that needs adjusting. It may or may not be under warrenty, read your paperwork. nipper Link to comment Share on other sites More sharing options...
chadwick35/04 Posted September 9, 2009 Author Share Posted September 9, 2009 Ok well the dealer told me that the extened warranty plan would probably cover it cause it was a great plan, so I dropped it off tonight for tomorrow I will let you all know. Link to comment Share on other sites More sharing options...
chadwick35/04 Posted September 12, 2009 Author Share Posted September 12, 2009 Well it turned out to be a switch that needs replacing in the dash, and it is covered under my warranty to, good times! Link to comment Share on other sites More sharing options...
