Markus56 Posted September 8, 2009 Share Posted September 8, 2009 replacing this with a piece of pop can? What's the right way to do this? Link to comment Share on other sites More sharing options...
pwjm Posted September 9, 2009 Share Posted September 9, 2009 you don't have any scrap metal you can use instead? You just need a plate of metal, drill two holes in it and bolt in on in place of the EGR. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 9, 2009 Share Posted September 9, 2009 If you just leave the hose disconnected it will be it's own block-off plate. Otherwise - use some 1/4" plate and drill/cut to fit. You should keep the EGR though - it lowers combustion temps and keeps your exhaust valves nice and cool. There's no reason to block it off. GD Link to comment Share on other sites More sharing options...
Markus56 Posted September 9, 2009 Author Share Posted September 9, 2009 Should there be oil in the diaphragm? Link to comment Share on other sites More sharing options...
idosubaru Posted September 9, 2009 Share Posted September 9, 2009 I just cut a piece of metal and drilled holes in it to bolt it in place. I've seen auto trans that won't shift properly when the EGR system is not functioning right. The benefits are probably better than the rare issues but I like my non-EGR engine with less junk on it. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 9, 2009 Share Posted September 9, 2009 Doesn't matter what's in the diaphram if you are using it as a block off by not hooking up the line. Bench test it, clean it, install it and properly hook it up. No problem. You can find many replacements that will fit in the junk yard. GD Link to comment Share on other sites More sharing options...
