oldschool Posted September 8, 2009 Share Posted September 8, 2009 I put a SJR 4 inch lift on my 87 gl wagon and 29 inch tires. All good and done , but you give it trottle when slowly rolling and the front end pulls hard to the right. When going down the high way the car drives great, also it wants to wheel hop real bad. Any suggestion to what is wrong? Thanks Robert in Portland Link to comment Share on other sites More sharing options...
ezapar Posted September 9, 2009 Share Posted September 9, 2009 Does it pull to the left when you decelerate? If so, it's a tie rod end or a bearing, or your castle nut on your axle is loose. Wheel hop means you need to balance that tire. Link to comment Share on other sites More sharing options...
one eye Posted September 10, 2009 Share Posted September 10, 2009 do you have the strut adjusted up? that can cause wheel hop aswell....... Jeff Link to comment Share on other sites More sharing options...
oldschool Posted September 11, 2009 Author Share Posted September 11, 2009 Yes I do have them adjusted up, but now I have a new AWD trans and a new rear diff to match, that is going in. It will now be AWD with 4:11 gears Link to comment Share on other sites More sharing options...
