replacing a 2001 2.5 with a 2001 2.2
I have done the early 2.5 dohc replacement several times. Wondering if the later 2.2 is a drop in, plug in and go replacement for the 2.5. Oh yeah can it be done with the phase 1 engine with some tricky mixing and matching of manifolds injectors etc. This is my personal car so im willing to experiment too nervous to do it on the customers cars. Thanks
OK so the 2.5 phase 2 on 2.2 phase 2 both have the same intakes? the earlier ones had different bolt patterns as i remember. Are the cam sprockets the same number of teeth but different timing marks for the sensors? If not what timing belt do you use? 2.5?
Intakes fit either 2.2 or 2.5 on phase 2. Cam and crank sprockets are the same except on the back where they trigger the sensor. 2.2 and 2.5 phase 2 use the same timing belt.
Tom,
Thanks. Great to know for when I take the leap to the Phase 2 engines. My only experience with a 99 Forester wasn't so pleasant.
Thanks 360. I saw another thread where someone put a phase II 2.5 >> in a 98 legacy. It looked like from his article that the phase 1 intake bolts to the phase 2 2.5 so are these the same too? Is it just the 2.5 dohc that has the different bolt pattern?
Tom,
Now that they are getting older, I do a lot with Phase 2 engines. They aren't any harder to deal with. I do a lot with 02-03 wrx also now that they are $6-7k cars.
That is a nightmare swap, phase 2 in 98 legacy. I will not do that one, not worth it. The Phase 1 2.5 dohc intake manifold does not fit on a phase 2 head.
