Crank Pully Question
markjw
I'm trying to put back together a ea82 engine that someone didn't finish a
oil pump/timing belt job on.
I had to go the the wrecking yard today for a crank pully (original one was lost). Found one,spun the crank bolt off and was on my way.
So,I go to install it on the end of the crank and it seems there should be a key way. Should there be? Or,is it just held on by the torque of the crank bolt?
I just did a bunch of front engine work on a ea82 a month ago. I can't remember this part.
Thanks. (I searched,no answer)
It's been awhile since I did an EA82.
On the ER27 (XT6 based off the EA82 - same pistons, valves, injectors, rings, bearings, etc), it has a pin in the crank pulley. The crank pulley has a hole that the pin is pressed into. This then slides into one of the holes in the timing sprockets on the crank shaft behind the pulley.
Either way, it's actually not necessary, but maintains proper alignment for timing off the crank pulley. Without it you can still time it off the flexplate/flywheel though through the bellhousing access hole.
I've installed tons of the XT6 ones without the pin in place, make sure they are TIGHT and they won't come off. I use a socket and 3 foot extension pipe and give it some good torque. It's not aluminum so no worries on stripping (well, i'm sure it's possible!).
Hi,
there is a keyway, but just for the two cam drive gears, there is a short roll pin in some of the outside cam drive gears and not in others. if your pulley has a hole like the one pictured you can use the roll pin, if the pulley has no hole then no roll pin. but if you get it tight with the bolt it does not matter. the timing is set from the flywheel so the pulley can be rotated to any position . i'm not sure why but i noticed that the engines that have the two piece crank pulley with the rubber imbedded in it used the pin and those with the 1 piece pulley had no pin, and i am not sure why they had two different pulleys anyway. seems the turbo and the mpfi had the two piece and carb and spfi had the 1piece pulley.
good luck with the repair
It almost looks like you could use a short roll pin from the hardware store (<$1)
it almost made me think it was a balancing hole in your pic, but I guess it does perfectly line up in the other piece
mine didn't have that feature, but on the other hand the pulley center bolt torque is pretty high - it hasn't done anything weird
