BRATDUDE Posted September 10, 2009 Share Posted September 10, 2009 I have a 2003 forester. Had to replace the condensor. I ran a vacuum on the system, when i try to put in the 34a coolant, the conpresor starts to lock up. I though it was a bad compressor, i switched compressors and it did the same thing. Any help out there? Link to comment Share on other sites More sharing options...
Scoobywagon Posted September 10, 2009 Share Posted September 10, 2009 SOunds like you're trying to feed in liquid 134a on the low side. Charging should be done on the high side. If you're using one of the cheap recharge kits you can get from Schuck's and such, then you don't have a choice. If that's the case, leave the can upright so that it will draw vapor instead of liquid. The refrigerant will happily boil off. If that goes too slowly for you, you can use a heat gun to heat the can. Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 14, 2009 Author Share Posted September 14, 2009 took it to a local repair shop today, they tried to vac and recharge and it did the same thing. the said it appears to him that the expansion valve is either stoped or not working. has anyone had this problem before? i know it is behind the dash, how hard it is to get to? help!!in fl it is really "no cool " to have no a/c. Link to comment Share on other sites More sharing options...
Scoobywagon Posted September 16, 2009 Share Posted September 16, 2009 If the expansion valve is shot, its a real chore to get. Its all the same work as a heater core swap. Pull the dash, pull the heater box, swap the valve, put it all back together. Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 16, 2009 Author Share Posted September 16, 2009 Is there any way to tell if that is the problem before i tear into the dash? Link to comment Share on other sites More sharing options...
Scoobywagon Posted September 16, 2009 Share Posted September 16, 2009 Without looking at the car with a set of guages, I just don't know. To diagnose it yourself, you'll need a good set of manifold guages and some reference materials. I'll be happy to help with that. What you're going to do is run the system and watch both high and low pressures to see where the refrigerant is going and what its doing when it gets there. Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 16, 2009 Author Share Posted September 16, 2009 I took it to a local mechanic that is knowledgable in the mechanics of the a/c system. The way he explained to me was that the system would recharge without a problem, no leaks, the presure got so high it would slow down the clutch and then blow it's top,(the presure valve on the side of the condensor would engage) i changed the ac compressor thinking that was the problem. I guess he probably know what he is talking about. What i could really use to you have the step by step directions on how to get to the expansion valve, that would truly help. My email address is subarucity@aol.com Link to comment Share on other sites More sharing options...
Scoobywagon Posted September 16, 2009 Share Posted September 16, 2009 Email sent w/ attachment Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 18, 2009 Author Share Posted September 18, 2009 Well i got the old one off, i was quoted 110.00 at a local subaru dealership. Is that high or average price. Can you receommend somewhere else. I do thank you for the instructions to take it off. Is this a dealler item only? Or can you buy it at any local parts store? Link to comment Share on other sites More sharing options...
Scoobywagon Posted September 18, 2009 Share Posted September 18, 2009 Parts store probably won't have it in stock, but should be able to order one. Depending on where they source it, you're probably looking at 3-4 days to get it. The best supplier, aside from the dealer, is probably Ranshu out of Reno, NV. They don't do retail sales, but if your parts store doesn't know where to get one, refer them to Ranshu. Link to comment Share on other sites More sharing options...
