jonas Posted September 19, 2015 Share Posted September 19, 2015 UGH! http--,,--// Link to comment Share on other sites More sharing options...
jonas Posted September 19, 2015 Share Posted September 19, 2015 Floor pan same area. http--,,--// Link to comment Share on other sites More sharing options...
jonas Posted September 19, 2015 Share Posted September 19, 2015 Even better! Did all that damage with my fingers. I have some POR-15 on the way. http--,,--// Link to comment Share on other sites More sharing options...
JPs1986brat Posted September 19, 2015 Share Posted September 19, 2015 Today was a busy day. First I bed lined the bed. After that I modified a GL wagon bumper to fit her. Then I started on my body work Link to comment Share on other sites More sharing options...
Rust Posted September 21, 2015 Share Posted September 21, 2015 Invested $20 into my sedan. Found a front spoiler at the dump = $0 Got a set of fog lights at harbor freight for $15 And $5 on a can of rattle can spray to freshen up the rims. 1 Link to comment Share on other sites More sharing options...
l75eya Posted September 21, 2015 Share Posted September 21, 2015 $20 well spent, Mr. Rust. Looks fresh! Link to comment Share on other sites More sharing options...
MR_Loyale Posted September 22, 2015 Share Posted September 22, 2015 Ash got a new windshield today. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 22, 2015 Share Posted September 22, 2015 (edited) had a low beam bulb go out on the WRX, installed a pair of GE Nighthawk bulbs. fairly easy, right side - just 2 bolts to remove the intake funnel. Left side, one clip to shift the wiper fluid filler tube - it was tight, if I had sausage fingers, probably have to remove the battery. Edited October 8, 2015 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
wagonist Posted October 8, 2015 Share Posted October 8, 2015 Been busy. Gutted the interior of the new wagon, so I can get it cleaned better & see if the stains come out. Removed the radiator & found out that the seal on the drain port was broken. hopefully, this was the reason there was no coolant and not because of an engine issue. Link to comment Share on other sites More sharing options...
belacane Posted October 11, 2015 Share Posted October 11, 2015 (edited) I saved my Subie . My WRX had a blown head gasket (internal; coolant in combustion chamber), and I had to make a choice. I decided to fix her, and I am so glad I did! She's no longer going to be my DD, as I have a an XV crosstrek now, but I'm planning on some awesome joy rides on the weekends, and absolutely can't wait! Took her for a drive this morning and it felt so good. It was confirmation that I did the right thing Edited October 11, 2015 by belacane 2 Link to comment Share on other sites More sharing options...
comatosellama Posted October 27, 2015 Share Posted October 27, 2015 Fried the center diff on my impreza woods runner, need to weld that up now, gonna do the rear while I'm at it as well. 4 Link to comment Share on other sites More sharing options...
wagonist Posted November 9, 2015 Share Posted November 9, 2015 Well, I've been fault finding in my JDM turbo wagon & I'm stumped. Won't kick the fuel pump in on it's original "turbo" ECU. Managed to drive it off the trailer though with an NA ECU... Anyone got any ideas can refer to here: http://www.ultimatesubaru.org/forum/topic/156337-error-code-22-ea82t-1990-model-ecu-questions/ Link to comment Share on other sites More sharing options...
jono Posted November 17, 2015 Share Posted November 17, 2015 (edited) searched and searched in here for the post on LED conversion for twin light EA81 Brumby. No findy Had a moment to try the 3 rows of LED in a quad light size on the outer low beam. Needed to be rigged to work not just plugnplay. I considered too btright and scattered to trust oncoming drivers not to be blinded [but given the test drive later - others LED lights from factory have no regard !) These work nice in the high beam inner position - plug and play. Just need longer M4 bolts 16mm would do, I got 20mm- [not tapered, so not calling them screws! ] Yes, LED highbeam light is better - and different .....bit like flouro light different to incandescant in houses. I would love to try the low beams that run the bottom row and centre LED of middle row once wired correctly and drive towards my car on dark nights, wet dark nights to experience just what they do to oncoming drivers eye ! Would lve to see road hazards before i feel them sourced from China ebay seller also, as I had to release male terminals from the plug, zapped something lost bright low beam when returned to std lights, got that typical low yellow glow often seen in old datsun/Nissans of the 80's. Found i blew the fuse panel fuse for that light. i could not just rewire led to get low and high work while inner highbeam light connected. To dod would need the wiring mod with extra relays Edited November 17, 2015 by jono Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 18, 2015 Share Posted November 18, 2015 Dear Jono, ... LED conversion for twin light EA81 Brumby ... These work nice in the high beam inner position - plug and play. Just need longer M4 bolts 16mm would do, I got 20mm ... LED highbeam light is better - and different ... How could you post such information regarding something very Visual, without adding Photos?Please, share some with Us, I'll like to see your Brumby with the LED Headlights' setup, also it would be interesting to see how they illuminates the Road.Kind Regards. Link to comment Share on other sites More sharing options...
Tom0 Posted December 12, 2015 Share Posted December 12, 2015 Got my recaro seats installed, finally. Unfortunately they sit too high for my liking. I should of taken more off of the base but i wanted to keep a brace that went across them. Ahh well, they are comfy. Also got tyres on my mag wheels, finally. Pictureshttp://puu.sh/lSNpC/a353944253.jpg http://puu.sh/lSNsy/609a62e4af.jpg http://puu.sh/lSNuR/264472c6f3.jpg http://puu.sh/lSNw4/40d0b7a38c.jpg http://puu.sh/lSNwV/cce2b44003.jpg http://puu.sh/lSNyK/42b0fda8cb.jpg http://puu.sh/lSNz8/be78227dfd.jpg Link to comment Share on other sites More sharing options...
subnz Posted December 13, 2015 Share Posted December 13, 2015 (edited) Haven't done it yet but still thinking about engine / driveline upgrade for Brat /Brumby Phase 1 SOHC N/A EJ22 for simplicity reliabilty non interference and mid range. matched to an 86/88 RX driveline ie 5MT AWD D/R centre locking diff with rear LSD (unfortunately rare as hens teeth) but probably won't happen as cost + components difficult too source. etc. So probably end up just rebuilding its EA81 and leaving it original. as motor tired using a quart every 600 miles (still runs ok :-) but hungry Dreams are free Edited December 13, 2015 by subnz Link to comment Share on other sites More sharing options...
Tom0 Posted December 13, 2015 Share Posted December 13, 2015 ^ That actually reminds me of the other thing I did recently haha, bought an rx driveline for future use in my wagon. 5speed dual range diff lock, rear lsd.Cost a fair bit, but hey, they're still printing money. http://puu.sh/lTJxq/3edfbf53e8.jpg http://puu.sh/lTJyZ/75db7b160b.jpg http://puu.sh/lTJyq/dc4e43345f.jpg 2 Link to comment Share on other sites More sharing options...
subnz Posted December 13, 2015 Share Posted December 13, 2015 ^ That actually reminds me of the other thing I did recently haha, bought an rx driveline for future use in my wagon. 5speed dual range diff lock, rear lsd. Cost a fair bit, but hey, they're still printing money. http://puu.sh/lTJxq/3edfbf53e8.jpg http://puu.sh/lTJyZ/75db7b160b.jpg http://puu.sh/lTJyq/dc4e43345f.jpg wow its all there, even gear lever surround with diff lock switch - might have to come and steal it Link to comment Share on other sites More sharing options...
Tom0 Posted December 14, 2015 Share Posted December 14, 2015 Yeah haha, only things I am missing are the two vacuum solenoids, which isn't too much of an issue. 1 Link to comment Share on other sites More sharing options...
leonel.fernandez Posted December 15, 2015 Share Posted December 15, 2015 Made this work, wasnt to bad a install. Had to trim down the rad cover is all. Also, a recent pic... That RX!!!!!!! 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 15, 2015 Share Posted December 15, 2015 What Have I Done to my Soobie lately? Mistakenly, I Cracked the Windshield! I opened the Hood to check for a Loose battery post connection, without noticing that my Little Daughter, left a small Plastic toy hiding on the opening at the Windshield's base, behind the Hood; so, when I opened the Hood, I heard a loud "CRACK!" sound, and saw that the Hood pressed the plastic toy against the Windshield's base... Kind Regards. Link to comment Share on other sites More sharing options...
987687 Posted December 15, 2015 Share Posted December 15, 2015 I've done that before with a wrench or something, felt really stupid. I did the same thing to my laptop screen last year, closed it with crap on the keyboard At least replacing that is cheaper and easier than a windshield... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 15, 2015 Share Posted December 15, 2015 Yes, I really felt Stupid doing that ... ... Now I'll search for another windshield and the Chromed plastic trims' Corners for it, because I lost the one on the lower corner of the Driver's side. Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 15, 2015 Share Posted December 15, 2015 The windshield was immaculate prior to this, but such things happens. Now, how to find the Trim's Chromed Corners... Kind Regards. Link to comment Share on other sites More sharing options...
DaveT Posted December 15, 2015 Share Posted December 15, 2015 Nuts. I did something sort of like that years ago. Put a 3/4" id 10 foot piece of pvc Condit diagonally across inside my wagon. Closed the back, No problem. Another trip, I buy a 2" id 10 foot piece. It doesn't bend as Much as the 3/4... looked like it fit and all, but when I closed the back, I cracked the windshield. Link to comment Share on other sites More sharing options...
