wilcox Posted April 19, 2012 Share Posted April 19, 2012 (edited) iaght lets try adding photos...... these are all of the pics of my new painted brake/hub parts. will have pics soon with new stuts and repainted springs, and it all intalled. Edited April 19, 2012 by wilcox Link to comment Share on other sites More sharing options...
wilcox Posted April 19, 2012 Share Posted April 19, 2012 ok watch out usmb this BAMF just figured out how to add pics... http://img11.imageshack.us/img11/2695/dscn0672f.jpg dont have the new stuts, but here is the other side before i took it apart Link to comment Share on other sites More sharing options...
TheLoyale Posted April 19, 2012 Share Posted April 19, 2012 LMAO! You go man, you go! The stuff looks good recoated. Did you blast them? I suppose they weren't all that rusty to begin with..? Link to comment Share on other sites More sharing options...
wilcox Posted April 19, 2012 Share Posted April 19, 2012 then you would be wrong, yeah i took them to school and sand blasted them. if you look at the pic when the one side is still installed you can see on the stut bolt it is still raw silver. they were pretty damn rusted, but a coat of duplicolor solved that! Link to comment Share on other sites More sharing options...
TheLoyale Posted April 19, 2012 Share Posted April 19, 2012 then you would be wrong, yeah i took them to school and sand blasted them. if you look at the pic when the one side is still installed you can see on the stut bolt it is still raw silver. they were pretty damn rusted, but a coat of duplicolor solved that! I really need to invest in a Sand Blaster, sure beats wire wheeling all my parts. I wonder how plastic beads would have done vs Sand? Link to comment Share on other sites More sharing options...
wilcox Posted April 19, 2012 Share Posted April 19, 2012 unless you are blasting thin sheat metal body panels use sand, or glass bead ( pricey though) plastic bead doestnt work as well as sand, unless your blasting body panels and dont want to warp the metal because of the heat from fricion. IE; sand causes more friction than plastic HARBOR FRIEGHT IT UP!!! Link to comment Share on other sites More sharing options...
TheLoyale Posted April 19, 2012 Share Posted April 19, 2012 Hmm.... http://www.ebay.com/itm/Portable-Air-Sandblaster-Gun-Tools-Blaster-Gravity-Feed-/290548637148?pt=Sanders_Sandblasters&hash=item43a60c5ddc#ht_2218wt_871 Link to comment Share on other sites More sharing options...
TheLoyale Posted April 19, 2012 Share Posted April 19, 2012 I have never used any type of Media blaster, so, how quickly do you go thru Sand, Beads, ect? I just imagine Sand pouring out lol. Suppose I should look it up on youtube. Link to comment Share on other sites More sharing options...
TheLoyale Posted April 19, 2012 Share Posted April 19, 2012 Subruise stuck on some "Subaru Alliance" decals onto his '91 Loyale. Link to comment Share on other sites More sharing options...
Subruise Posted April 19, 2012 Share Posted April 19, 2012 Subruise stuck on some "Subaru Alliance" decals onto his '91 Loyale. you cant see em but the bruise is rollin new pads all the way around too. gonna be relplacing calipers in the near future, along with new rear rotors:D Link to comment Share on other sites More sharing options...
FlatFourFrenchy Posted April 20, 2012 Share Posted April 20, 2012 Thank God for donor wagon. First the fuel pump donaton got me on the road the other day, today I went out to check fluids and the hood release cable snapped. Luckily it had popped open at the same time the cable broke. The donorwagon was happy to help out my daily driver. Link to comment Share on other sites More sharing options...
wilcox Posted April 20, 2012 Share Posted April 20, 2012 I have never used any type of Media blaster, so, how quickly do you go thru Sand, Beads, ect? I just imagine Sand pouring out lol. Suppose I should look it up on youtube. ya it is about 80 psi so you dont even see the sand you just have to track the new shiny spot on the metal to see where your at. that sand blaster you picked out will work but you will have to use it out side. on the plus side though you wont have a size constraint. if you get a blast cabinet it will allow you blast in a controlled environment, other wise you will need goggles and a face mask cause that sand is like worse that aspestos. Link to comment Share on other sites More sharing options...
TheLoyale Posted April 20, 2012 Share Posted April 20, 2012 Thanks for the info, I've been talking with TomRhere and he mentioned the same aspects that you did Thank you it will all stick in my head. So the sand is as bad as the "Dusty Bowl" dust? Haha.. Am I gonna die of Black lung? ya it is about 80 psi so you dont even see the sand you just have to track the new shiny spot on the metal to see where your at. that sand blaster you picked out will work but you will have to use it out side. on the plus side though you wont have a size constraint. if you get a blast cabinet it will allow you blast in a controlled environment, other wise you will need goggles and a face mask cause that sand is like worse that aspestos. Link to comment Share on other sites More sharing options...
wilcox Posted April 20, 2012 Share Posted April 20, 2012 Thanks for the info, I've been talking with TomRhere and he mentioned the same aspects that you did Thank you it will all stick in my head. So the sand is as bad as the "Dusty Bowl" dust? Haha.. Am I gonna die of Black lung? pretty much ive use the media blasters like the one on ebay your looking at, if you dont wear a mask it is way worse that you could imagine, and the clean up is terrible. at least with a blast cabinet you can re-use the media. if you use one like that you cant reuse it unless your in a controlled area were it would fall on a tarp. Link to comment Share on other sites More sharing options...
TheLoyale Posted April 20, 2012 Share Posted April 20, 2012 I have the idea of just using a metal box so I can capture most of the media. Tom mentioned building my own blast box. Seems rather easy, I'm just trying to keep size down, perhaps big enough to stick a 15" wheel in and that'd be good for me. I also had the idea of placing the part in a metal wash tube and then blast, should work fairly well (Also wear eye protection and a mask) Link to comment Share on other sites More sharing options...
wilcox Posted April 20, 2012 Share Posted April 20, 2012 to build a blask cabinet big enough for a 15" wheel would be a pain in the rump roast i think. now what might be more practical is to buy this from harbor freight and then modify it. ived used one there pretty nice! http://www.harborfreight.com/garage-shop/blast-cabinets/40-lb-capacity-floor-blast-cabinet-93608.html Link to comment Share on other sites More sharing options...
TheLoyale Posted April 20, 2012 Share Posted April 20, 2012 Possibly. Although, we'll never know unless I try I've been looking at Harbor freight, but really don't want to drop $200 on one. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 20, 2012 Share Posted April 20, 2012 I've seen inflatable blasting 'cabinets' - but not one big enough for a rim. I'd think you could put together something with PVC pipe. No good for a shop, but at home you may only need to blast something every few months so, a 'knock down' unit of some type would be OK. Might even be some good plans around at instructables or somewhere on the web. Link to comment Share on other sites More sharing options...
TheLoyale Posted April 20, 2012 Share Posted April 20, 2012 I've seen inflatable blasting 'cabinets' - but not one big enough for a rim. I'd think you could put together something with PVC pipe. No good for a shop, but at home you may only need to blast something every few months so, a 'knock down' unit of some type would be OK. Might even be some good plans around at instructables or somewhere on the web. I've actually seen one made out of an old Oil drum, Had a plexi-glass window, and rubber glove inserts, along with a Shop-vac hook up. Looked and worked pretty well. I like the idea of building one, I need to make my own welding cart as well. Link to comment Share on other sites More sharing options...
l75eya Posted April 20, 2012 Share Posted April 20, 2012 Got that thrown in Ben today. Was able to get it finagled into the stock position of the old electric fan. It sits about 1/4" away from the crank pulley, which I don't like, but there's nothing I can do to avoid that for now, so that's how it stays. Feels great to not have to watch the temp gauge all the time due to no fans. FYI, with an ambient temp range of 50-80 degrees (as it has varied from/to while the car was in a no fan state) our cars, with a fully functioning cooling system, will run in a safe temp range with absolutely NO cooling fans 95 percent of the time. I ran Ben with no fans for the past month 1/2 and the only time he ever started to heat up was sitting in traffic or while driving slowly looking for parking. Never did he hit the danger mark either. Link to comment Share on other sites More sharing options...
wilcox Posted April 20, 2012 Share Posted April 20, 2012 ^^^ took me a while to realize who ben was, ha ha Link to comment Share on other sites More sharing options...
wilcox Posted April 20, 2012 Share Posted April 20, 2012 (edited) ok here are some pics of the new painted spring, and spring top piece for the passenger side! before and after painting. i sand blasted both Edited April 20, 2012 by wilcox Link to comment Share on other sites More sharing options...
987687 Posted April 20, 2012 Share Posted April 20, 2012 I have to be at a rallyx 2 hours away from home at 7.30 tomorrow morning... Just replaced the wheel bearing in my car. HAH. Bout friggin' time! Link to comment Share on other sites More sharing options...
1982gl4 Posted April 21, 2012 Share Posted April 21, 2012 Got my wrx insured today, got that out, cleaned it, waxed it and took it for a rather brisk drive. Over all a good day Link to comment Share on other sites More sharing options...
skingry Posted April 21, 2012 Share Posted April 21, 2012 Decarbonized the engine using distilled water and a squirt bottle (about 3 cups through the engine). Throttle response is nice and smooth up to 4k on the tach now. Bought a dwell meter and set the idle mixture "by the book". Next up: timing and a new oil pump. Link to comment Share on other sites More sharing options...
