Txakura Posted September 11, 2014 Share Posted September 11, 2014 (edited) I found some chrome 6 bolt 14x7 rims and had 195/70-14 tires put on them. I figured they would look 'ok'. I bolted them to the RS to make it a little more driveable on the pavement. I can go to full lock, have better acceleration and finally shed an annoying vibration. Unfortunately, the chrome rims look truly hideous on the car. My GF laughed her self silly when she saw them. No I will not attach a picture. The RS is now pouting like a kid with a bad haircut. I may only drive it at night. Edited September 11, 2014 by Txakura 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 11, 2014 Share Posted September 11, 2014 On 9/11/2014 at 5:17 AM, Txakura said: ... No I will not attach a picture. ... I'll Like to see at least one photo of that... Kind Regards. 3 Link to comment Share on other sites More sharing options...
wagonist Posted September 11, 2014 Share Posted September 11, 2014 Ditto, it's Friday. The mood should be lightened before the weekend Link to comment Share on other sites More sharing options...
Vegablade Posted September 12, 2014 Share Posted September 12, 2014 Updated my 6 accessory fuse block to a 12. Also cleaned some more of the wiring up, still lots to do there. 4 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 13, 2014 Share Posted September 13, 2014 On 9/12/2014 at 12:50 AM, Vegablade said: Updated my 6 accessory fuse block to a 12... Looks solid built and very Clean, Well Done! It is interesting that I chose exactly the Same spot on the engine bay of my "BumbleBeast" to place a similar but simplier Relay Box, instead the old, exposed relays Setup that came from Factory... Kind Regards. 1 Link to comment Share on other sites More sharing options...
jmoss5723 Posted September 15, 2014 Share Posted September 15, 2014 Yesterday I changed the tranny oil in the BRAT. It had been having some trouble in second gear with crunchy shifting and popping out of gear when cold. I suppose it was more like it wouldn't get all the way into gear and would pop out. Once I really got it into second, it would hold fine. Also, it wouldn't let me get into first until I was as close to completely stopped as you can get. Obviously changing the oil won't eliminate these problems entirely, but I figured it would probably help and it would give me some insight into what might be going on inside the tranny. The oil was really cloudy, but no major metal pieces, which is always good. I filled it up with Valvoline 80-90 because I'm poor and a gallon is only $20. The oil went in REALLY slowly, which seemed weird to me. the funnel was sitting there full and the level went down at about 1 quart/5 minutes. Every once in a while a big air bubble would pop up and oil would flow better for a little bit. Anyways, the tranny is noticeably better now, but certainly not perfect. Link to comment Share on other sites More sharing options...
jmoss5723 Posted September 15, 2014 Share Posted September 15, 2014 On 9/8/2014 at 4:28 AM, jj421 said: Just figured I'd give a quick update to my steering failure adventure, since you guys responded. What caused me to lose steering was half of my engine subframe bolts sheered off. My Loyale is lifted, and I have a subframe drop. When I originally put the drop in, I didn't have any big drill bits and I was too cheap to buy some. So I decided it would be fine to just run skinny 1/4" bolts to hold my subframe on. 1/4 INCH BOLTS?! And you've wheeled and JUMPED it? You must have a death wish! 1 Link to comment Share on other sites More sharing options...
Sapper 157 Posted September 15, 2014 Share Posted September 15, 2014 (edited) Since the car came under my ownership in April the following are the things I have improved/replaced/upgraded on my 84 GL wagon standard tranny....New LED flood lights producing 2,300 extra lumens in addition to my dims.New beltDrained old coolant and replaced with fresh stuff.Fixed my hazard lightsNew windshield wipers New speakers New spark plugsNew fuel filterRepaired overhead lightSprayed the interior with armorallNew seat coversNew clutch cableNew starterNew oil pan gasketUpgraded 10 bladed electric fan replacing the old 4 bladed oneReplaced tranny fluidAdded survival kit and tool kit to the back.Added extra carpet to the backReplaced air filterFilled chips in windshieldSprayed corrosion stopper on battery terminalsDrained oil and replaced with full synthetic 10w-30 oil and slapped on an ultra premium filterI've also been running Seafoam through it. Edited September 15, 2014 by Sapper 157 Link to comment Share on other sites More sharing options...
Sapper 157 Posted September 15, 2014 Share Posted September 15, 2014 On 9/15/2014 at 3:32 PM, jmoss5723 said: the oil went in REALLY slowly, which seemed weird to me. the funnel was sitting there full and the level went down at about 1 quart/5 minutes. Every once in a while a big air bubble would pop up and oil would flow better for a little bit. It helps if you lift up the funnel just a little. this releases the pressure that is making it difficult for the fluid to enter the tranny. Same thing happens with a gas can. on most cans they have a little plug at the back and if you undo that plug the gas flows much faster...the same is true with tranny fluid Just a little tid bt for the future Link to comment Share on other sites More sharing options...
987687 Posted September 15, 2014 Share Posted September 15, 2014 Still don't fill the trans too fast, or it'll burp a big belch of oil out of the dipstick... All over the cat. Which smells great for the next few miles Link to comment Share on other sites More sharing options...
jmoss5723 Posted September 15, 2014 Share Posted September 15, 2014 On 9/15/2014 at 7:47 PM, Sapper 157 said: It helps if you lift up the funnel just a little. this releases the pressure that is making it difficult for the fluid to enter the tranny. Same thing happens with a gas can. on most cans they have a little plug at the back and if you undo that plug the gas flows much faster...the same is true with tranny fluid Just a little tid bt for the future On 9/15/2014 at 7:48 PM, 987687 said: Still don't fill the trans too fast, or it'll burp a big belch of oil out of the dipstick... All over the cat. Which smells great for the next few miles Seems like if air is struggling to escape through the funnel, it would have the same issue through the dipstick tube with the funnel pulled up. Wouldn't it just run out of the funnel and up over the top of the tube? Now this has me wondering, do these transmissions have a breather tube? If yes, is it hooked to a vacuum line or is it just a passive breather? I'd think if it DOES have a breather and the tranny is burping when I fill it, maybe that breather is clogged? the fact that it is burping makes me think it must not have one. Link to comment Share on other sites More sharing options...
987687 Posted September 15, 2014 Share Posted September 15, 2014 Every subaru trans (and auto front diff) has done this to me. I always just assumed it breathed through the dipstick hole. Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted September 15, 2014 Share Posted September 15, 2014 You know, you could always spin the drain plug out and the gear oil will pour in super fast. Twitch PS: Don't try this at home kiddos 2 Link to comment Share on other sites More sharing options...
jmoss5723 Posted September 15, 2014 Share Posted September 15, 2014 On 9/15/2014 at 10:33 PM, Twitch de la Brat said: You know, you could always spin the drain plug out and the gear oil will pour in super fast. Twitch PS: Don't try this at home kiddos Duh! Why didn't I think of that?! So much wisdom on this site. Link to comment Share on other sites More sharing options...
Sapper 157 Posted September 15, 2014 Share Posted September 15, 2014 On 9/15/2014 at 8:39 PM, jmoss5723 said: Seems like if air is struggling to escape through the funnel, it would have the same issue through the dipstick tube with the funnel pulled up. Wouldn't it just run out of the funnel and up over the top of the tube? Now this has me wondering, do these transmissions have a breather tube? If yes, is it hooked to a vacuum line or is it just a passive breather? I'd think if it DOES have a breather and the tranny is burping when I fill it, maybe that breather is clogged? the fact that it is burping makes me think it must not have one. That is a VERY good question. Id like to know the same about my wagon. I think ill create a new thread and see what everyone else says about it. (Love this site!) Link to comment Share on other sites More sharing options...
MR_Loyale Posted September 15, 2014 Share Posted September 15, 2014 (edited) Thursday I did surgery on my keyless entry FOB that quit working when I had it in my pocket as I swam in the Gulf of Mexico. The salt water had shorted the batteries and it looked rusty inside. I washed the circuit board in the melted cooler water. Turns out a trip to Walgreens, an eyeglass repair kit (for the tiny screw driver) and a scotch brite pad and the keyless entry works once again. I did all this in a quick stop in Mobile Alabama. Edited September 16, 2014 by MR_Loyale Link to comment Share on other sites More sharing options...
987687 Posted September 16, 2014 Share Posted September 16, 2014 Next time you're better off not to scratch the contacts trying to clean them. This will increase their surface area and remove the surface coating so it'll be much more likely to corrode in the future. Usually I'll use electronics cleaner and one of those black erasers for pen. You can usually pick them up at art stores, etc. Just "erase" the corrosion and crap off the board to clean it up. This generally gives you a much better repair and longer service life. Also a toothbrush is great for scrubbing the surface without removing any coating. Link to comment Share on other sites More sharing options...
Tom0 Posted September 16, 2014 Share Posted September 16, 2014 Had the carpets and everything to get said carpets out of my 83 sedan, coated the floor in a sealer, put everything back in and found that its definitely leaking through the doors/windows on the passenger side. Waiting on a call back from local Subaru dealer to see if they can source them, not holding my hopes up though. Also did fuel filter, hoping that it might help with stuttering hard ride hand corners (didn't), then changed Oil and filter on my wagon. Link to comment Share on other sites More sharing options...
rrgrr Posted September 16, 2014 Share Posted September 16, 2014 Changed the my alternator belt after it wrapped itself around the fan, stopped the water pump and caused an overheat. I was just having a nice trip when I looked down and saw all red! Helpful motorist donated several water bottles and I made it ~10 miles with no alternator running no problem. Link to comment Share on other sites More sharing options...
Sapper 157 Posted September 16, 2014 Share Posted September 16, 2014 (edited) On 9/15/2014 at 8:39 PM, jmoss5723 said: Seems like if air is struggling to escape through the funnel, it would have the same issue through the dipstick tube with the funnel pulled up. Wouldn't it just run out of the funnel and up over the top of the tube? When I replaced my tranny fluid I used the trick I told you about (lifting up the funnel a little to release the vacuum effect on the oil) and it worked fine for me, no spilled oil. the trick is lifting it up just a LITTLE. just enough to make a gap between the side of the funnel and the side of the dipstick hole. sometimes this requires to people, one to pour the liquid and one to hold the funnel. Edited September 16, 2014 by Sapper 157 Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted September 16, 2014 Share Posted September 16, 2014 On 9/16/2014 at 3:25 PM, Sapper 157 said: When I replaced my tranny fluid I used the trick I told you about (lifting up the funnel a little to release the vacuum effect on the oil) and it worked fine for me, no spilled oil. the trick is lifting it up just a LITTLE. just enough to make a gap between the side of the funnel and the side of the dipstick hole. sometimes this requires to people, one to pour the liquid and one to hold the funnel. Next time, tape a toothpick to the side of the funnel before pouring Twitch 4 Link to comment Share on other sites More sharing options...
rrgrr Posted September 20, 2014 Share Posted September 20, 2014 Here's the "header" I had made after my cat gave it up: 2" to stock style muffler. It pops a little bit from the back if I'm slowing in too high a gear, but not bad. It's getting varnished Changed the oil pan gasket to try and clean it up... And there's this... Check out my build thread for the deets! http://www.ultimatesubaru.org/forum/topic/140492-back-on-the-wagon/page-3#entry1250047 Link to comment Share on other sites More sharing options...
MR_Loyale Posted September 21, 2014 Share Posted September 21, 2014 Washed half of New Mexico off Uno. Got tires rotated and did an oil change. 1 Link to comment Share on other sites More sharing options...
Subarocket Posted September 21, 2014 Share Posted September 21, 2014 Just bought a dual range for Betty White, my Loyale, from crawlerdan. Time for a road trip to Mantana! Link to comment Share on other sites More sharing options...
Vegablade Posted September 23, 2014 Share Posted September 23, 2014 Just installed this tonight. Volt meter battery terminal. 5 Link to comment Share on other sites More sharing options...
