hueyman2 Posted September 14, 2009 Share Posted September 14, 2009 I want to replace my current fog lamps/lights with much brighter ones. Should I replace the whole assembly or just upgrade to higher intensity bulbs. For either do you have any suggestions on make and model of the parts? Thanks! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 14, 2009 Share Posted September 14, 2009 the sylvania silverstars seem to do fine, i just installed them last week in mine, they're a step up from the stock. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted September 14, 2009 Share Posted September 14, 2009 the sylvania silverstars seem to do fine, i just installed them last week in mine, they're a step up from the stock. I am thinking that silverstars are head light bulbs only, not fog lamps. Someone wrote here about replacing fog lamps with low beam seal beam bulbs. I am sure doing a "search" here will tell you all about the conversion. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 14, 2009 Share Posted September 14, 2009 I am thinking that silverstars are head light bulbs only, not fog lamps.on the H6 OBW's like mine (i'm sure the EJ25's are the same) the foglights use headlight bulbs. standard 9006 or something like that, forget the exact number. Quote Link to comment Share on other sites More sharing options...
hueyman2 Posted September 15, 2009 Author Share Posted September 15, 2009 Yea I upgraded to the most expensive "autozone" Sylvania "Silverstar" bulb's last time I replaced them but i want them BRIGHT...was thinking PIAA or another company if someone had suggestions. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 15, 2009 Share Posted September 15, 2009 I think you have to be careful upgrading too much or you can exceed the rating of the wiring that supports that circuit. folks upgrade the wiring often when going bonkers with bright lights. Quote Link to comment Share on other sites More sharing options...
