Mbc
vagen
I just received a MBC bought on Ebay and I am a bit confused there is a "T" fitting with a ball and spring in it and an adjustable bleed valve. My question is if this is a bleed off type controller why is there a check valve?
I am thinking about removing the check valve and just treat it as a bleed valve.
I think I have the install down but the t fitting having a check ball confuses me.
I guess I had a misplaced idea that this was a spring valve controller instead of a bleed controller. I'm used to seeing the spring valve controllers.
Edited by vagen
I plan to use the Tee but not the spring and ball in the tee.
You might end up overboosting.
Then you can kiss that EA82T byebye.
Ask me how I know :rolleyes:
Actually, if you have a boost gauge, try it without the TEE completely.
If you dont get boost creep, it might be ok without it.
But I would use any MBC without keeping a sharp eye on the gauge.
Edited by Turbone
I have a gauge and I will be watching this like a hawk. I will not add any boost till I have the intercooler installed. The plan is to intercool and then add boost. I am planning to add an egt and a WBO2 to further monitor things.
the way they had the ball and spring positioned it would have increased boost pressure before it was regulated by the bleed valve.
like this
turbo {ovvvv} wastegate
.............T
boost adjustment valve
